Home » Eclipse Projects » Eclipse Platform » Best Practice for FormEditor's dirtyState/saving
Best Practice for FormEditor's dirtyState/saving [message #333958] Wed, 14 January 2009 11:58 Go to next message
I'm currently writing a formeditor and have a small problem updating the
dirty state as well as not saving in some cases.
The data for the editor comes from a model, which allows manipulation and
also has a listener-interface to notify about changes. The editor's GUI
elements now directly change the model and the editor gets notified as it
is a listener. So far no problem, now one of the GUI elements is a table
using cell editors and it turns out that those cell editors commit any
changes as soon as they loose focus. Most of the time that is ok, except
when they loose focus because the user clicked on the close button of the
editor.
I'm wondering now how others do this, I'd like to avoid creating a duplicate
of the model's data in memory, but thats the only viable option I see right
now.
Andreas
Re: Best Practice for FormEditor's dirtyState/saving [message #333962 is a reply to message #333958] Wed, 14 January 2009 12:44 Go to previous messageGo to next message
Andreas Pakulat wrote:
> editor.
> now.
> Andreas
I use the Eclipse Modeling Framework to build form editors just to get
all that cruft handled without having to think about it.
Steve
Re: Best Practice for FormEditor's dirtyState/saving [message #333964 is a reply to message #333958] Wed, 14 January 2009 12:48 Go to previous messageGo to next message
On 1/14/2009 11:58 AM, Andreas Pakulat wrote:
> editor.
> now.
The way we do it in Skyway is to override
org.eclipse.ui.part.EditorPart.isSaveOnCloseNeeded() and in there check
if one of this editor's widgets has focus; if so we force a focus-out event.
public boolean isSaveOnCloseNeeded() {
// If one of this editor's widgets has focus, make sure it fires change
notification to
// update the model before asking if save is needed.
Control focusedChild =
EclipseUIUtils.getFocusedChild(getActivePageInstance().getMa nagedForm().getForm());
if (focusedChild != null) {
focusedChild.notifyListeners(SWT.FocusOut, null);
return super.isSaveOnCloseNeeded();
Hope this helps,
Eric
Re: Best Practice for FormEditor's dirtyState/saving [message #333986 is a reply to message #333964] Thu, 15 January 2009 06:20 Go to previous messageGo to next message
>> editor.
>> duplicate of the model's data in memory, but thats the only viable option
>> I see right now.
> event.
Well, that doesn't really help here. The focus loosing already works as
expected. The problem is that there doesn't seem to be a hook to do
something if the user chose "No" on the save-dialog, hence I cannot reset
my model for that case.
Andreas
Re: Best Practice for FormEditor's dirtyState/saving [message #333988 is a reply to message #333962] Thu, 15 January 2009 06:21 Go to previous messageGo to next message
>> editor.
>> I see right now.
>> Andreas
I'll have a look, but frankly, adding yet another model on top of my model
(which already is a model on top of a non-eclipse pure java model) doesn't
sound too good :)
Andreas
Re: Best Practice for FormEditor's dirtyState/saving [message #333998 is a reply to message #333986] Thu, 15 January 2009 09:10 Go to previous messageGo to next message
On 1/15/2009 6:20 AM, Andreas Pakulat wrote:
>>> Hi,
>>> editor.
>>> I see right now.
>> event.
I guess you'll have to try to explain your problem in a different way,
because it sounded to me that you were facing the problem that closing
the editor while a widget has focus is not triggering a focus-lost
event, but rather just going into the sequence that calls
isSaveAsCloseNeeded().
After re-reading your original question and the follow-up, I have no
idea the exact scenario you are trying to handle.
Eric
Re: Best Practice for FormEditor's dirtyState/saving [message #334009 is a reply to message #333998] Thu, 15 January 2009 11:37 Go to previous messageGo to next message
>>>> Hi,
>>>> the dirty state as well as not saving in some cases.
>>>> and also has a listener-interface to notify about changes. The editor's
>>>> GUI elements now directly change the model and the editor gets notified
>>>> as it is a listener. So far no problem, now one of the GUI elements is
>>>> a table using cell editors and it turns out that those cell editors
>>>> commit any changes as soon as they loose focus. Most of the time that
>>>> is ok, except when they loose focus because the user clicked on the
>>>> close button of the editor.
>>>> option I see right now.
>>> event.
My problem is that even if I manage to let the editor part know that its
dirty and might need saving, choosing "no" on the dialog doesn't call
anything on my editor class. However as the current implementation is I'd
need to have that, because I need to re-set the model to the original
state, as the model is changed with every change in my editor.
Andreas
Re: Best Practice for FormEditor's dirtyState/saving [message #334085 is a reply to message #334009] Mon, 19 January 2009 16:31 Go to previous message
So you have a in-memory model that is somehow shared or otherwise needs
to be revertable, correct?
I'd say in that case, you're going to need some kind of buffer in
between the "authoritative" model and the version that the editor is
working. (normally, memory is the buffer between persistence (ie, file
system) and the editor).
I don't think there is a simple solution to that problem, but JFace Data
Binding could probably help. Have you looked into it yet?
Eric
Previous Topic:Editor window persistence problem
Next Topic:Set Color of Main RCP Workbench window Border.
Current Time: Sat Aug 30 12:10:43 EDT 2025
Powered by FUDForum. Page generated in 0.07360 seconds
