Home » Eclipse Projects » Eclipse Platform » Undo does not work in 3.4?
Undo does not work in 3.4? [message #333946] Wed, 14 January 2009 10:58 Go to next message
Originally posted by: paul.paulgalbraith.net
Basic undo functionality does not seem to work in the text editors in
eclipse 3.4, has anyone else noticed this problem? I'm assuming I'd
see/hear a lot more about this if everyone else was having the same
problem, but figured I'd ask just in case someone else out there has
this problem, too?
Re: Undo does not work in 3.4? [message #333950 is a reply to message #333946] Wed, 14 January 2009 11:28 Go to previous messageGo to next message
> this problem, too?
Works fine here using Eclipse SDK.
Dani
Re: Undo does not work in 3.4? [message #333954 is a reply to message #333946] Wed, 14 January 2009 11:38 Go to previous message
"Paul Galbraith" <paul@paulgalbraith.net> wrote in message
news:gkl233$daq$1@build.eclipse.org...
> problem, but figured I'd ask just in case someone else out there has this
> problem, too?
I think your assumption is correct, although one way to check is to search
for bug reports in Bugzilla. (FWIW, undo seems to be working fine for me;
I'd perish in minutes without it.)
Can you be more specific about exactly what you're doing (what OS, exact
Eclipse version, exact repro steps)?
Does it happen if you create a fresh workspace, fresh project, and fresh
file?
Do you have any third-party plugins installed that might be interfering?
Are there any errors reported in the error log (PDE Runtime Perspective ->
Errors View)?
Does it fail regardless of how you try to access the command, i.e., from the
menu as well as from keyboard shortcut?
Previous Topic:Using custom image in the preview page in our extended refactoring
Next Topic:Invoking Find/Replace
Current Time: Thu Jul 17 23:44:25 EDT 2025
Powered by FUDForum. Page generated in 0.07263 seconds
