Home » Eclipse Projects » Eclipse Platform » Add control to status bar
Add control to status bar [message #333931] Wed, 14 January 2009 06:03 Go to next message
I added a control in my status bar. And I would like to manage the display
of this control with preferencePage, as the "Heap status" in Preferences >
General. But my problem is to modify the visibility of my control when I
modify my preference, because I don't know how I link my extended
"WorkbenchWindowControlContribution" class and my preferencePage, in order
to refresh/reload the status bar.
Thanks.
David.
Re: Add control to status bar [message #333933 is a reply to message #333931] Wed, 14 January 2009 07:59 Go to previous messageGo to next message
Visibility of a menuContribution is controlled by its visibleWhen
contribution. If you were to create a property tester for your
preference you could listen for preference changes and re-evaluate it
with org.eclipse.ui.services.IEvaluationService.requestEvaluation (String)
PW
Paul Webster
Re: Add control to status bar [message #333941 is a reply to message #333933] Wed, 14 January 2009 09:56 Go to previous messageGo to next message
I have added :
<control
class=control.ConnexionControl"
id="control.ConnexionControl">
<visibleWhen
checkEnabled="false">
<with
variable="displayState">
<equals
value="true">
</equals>
</with>
</visibleWhen>
</control>
to my control, and I call :
IEvaluationService service =
(IEvaluationService)PlatformUI.getWorkbench().getService(IEv aluationService.class);
service.requestEvaluation(displayState);
in the PreferencePage performOk() method., but it doesn't work.
What can be the problem?
Thx,
David.
Re: Add control to status bar [message #333974 is a reply to message #333941] Wed, 14 January 2009 15:01 Go to previous messageGo to next message
David wrote:
> I have added :
> <control
> <visibleWhen
> <with
> <equals
> value="true">
> </equals>
> </with>
> </visibleWhen>
> </control>
Variables are provided by a subclass of AbstractSourceProvider ... if
you are going to use variables you would need to use the
org.eclipse.ui.services extension point to provide one
1) you probably want to listen for changes to the preference to request
a re-evaluation not simply OK on the pref page.
2) you need to create a PropertyTester (see
http://wiki.eclipse.org/Command_Core_Expressions) to test your property.
requestEvaluation(*) is for properties, ISourceProviders are for
variables.
There should be an example of this in
org.eclipse.ui.examples.contributions, in CVS
:pserver:anonymous@dev.eclipse.org:/cvsroot/eclipse
PW
Paul Webster
Re: Add control to status bar [message #334153 is a reply to message #333974] Thu, 22 January 2009 04:13 Go to previous messageGo to next message
thanks for your help, but I have found an other solution which is :
ITrimManager trimManager =
((WorkbenchWindow)MyPlugin.getInstance().getWorkbench().getA ctiveWorkbenchWindow()).getTrimManager(); trimManager.getTrim("MyControl.toolbar" ).getControl().setVisible(plugin.getPreferenceStore().getBoo lean(STATE_ENABLED));
trimManager.forceLayout();
in my performOk() method of my preferencePage.
David.
Re: Add control to status bar [message #334163 is a reply to message #334153] Thu, 22 January 2009 14:05 Go to previous message
David wrote:
> Hello,
that's all internal code, so if it changes at any time you'll run into
problems, especially between releases.
Other than that (and if something like a resize causes changes to be
re-evaluated) you have to be careful of the cost of forcing a trim
re-layout.
PW
Paul Webster
Previous Topic:JFACE wizard next button implementation
Next Topic:Adding jars from file system to runtime classpath
Current Time: Thu Nov 06 20:36:18 EST 2025
Powered by FUDForum. Page generated in 0.04272 seconds
