| Rearrange dropins folder fails [message #333914] |
Tue, 13 January 2009 15:13  |
Hello!
I want to rearrange my dropins folder, but after rearranging the plugins
are not found anymore (the new layout is supported and works perfectly
in a fresh eclipse install).
By example:
I have my CDO Plugins installed in /dropins/eclipse/* (works fine) and
now move them to /dropins/cdo/eclipse/*.
But after doing that and restarting Eclipse (3.5M4) I get those errors
in the log:
ProvisionException
No repository found at
file:/C:/Users/superuser/eclipse/eclipse/eclipse_3.5_cdo_2/d ropins/cdo
If I unzip just a fresh Eclipse SDK and put the same directory layout in
the dropins folder everything works fine.
I tried to start Eclipse with the -clean argument, but this doesn't help.
Any suggestions how to rearranging the dropins folder?
Kai
| Re: Rearrange dropins folder fails [message #334041 is a reply to message #333970] |
Fri, 16 January 2009 08:18  |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=261344
Kai Schlamp schrieb:
> Ok, your method worked ... thanks a lot.
> But I find this procedure also a bit weird.
> It would be much more straightforward if a simple -clean would be enough.
> Shoud I create an enhancement request?
> Best regards,
> Kai
>>> Hello!
>>> plugins are not found anymore (the new layout is supported and works
>>> perfectly in a fresh eclipse install).
>>> By example:
>>> and now move them to /dropins/cdo/eclipse/*.
>>> errors in the log:
>>> ProvisionException
>>> in the dropins folder everything works fine.
>>> help.
>>> Best regards,
>>> Kai
>> Kai,
>> perhaps this helps you:
>> 1. remove all plugins you want to re-arrange from dropins folder
>> 2. start -clean and quit
>> 3. put plugins into new location, use a folder name you never used
>> before inside dropins with this eclipse installation
>> 4. start -clean
>> if you're in luck the plugins are there
>> ekke
FUDForum. Page generated in 0.03636 seconds
