Home » Eclipse Projects » Eclipse Platform » [Databinding] Validating at least one selection in a Checkbox Table Viewer
[Databinding] Validating at least one selection in a Checkbox Table Viewer [message #333872] Sun, 11 January 2009 15:37 Go to next message
I am using JFace Databinding and I need to validate that at least a single
item is selected in a checkbox table viewer.
I tried many things without success.
As the UpdateSetStrategy does not allow to provide a validator, I could not
find a nice solution to this.
I tried to use the MultiValidator also without success.
I also extended the doAdd and doRemove on the UpdateSetStrategy, but it does
not cover all required validation situations (like when the view/form is
first opened, before selecting or deselecting anything from the list).
Somebody has a snippet on how to provide this kind of validation? I have an
urgent requirement for this on the current project. Trying to consolidate
the rcp platform here.
Thanks for the help.
Marcelo Alcantara
Re: [Databinding] Validating at least one selection in a Checkbox Table Viewer [message #333887 is a reply to message #333872] Mon, 12 January 2009 12:12 Go to previous messageGo to next message
We should probably add validators to SetBinding. Would you file a bug?
Other than that, I'm pretty sure that you should be able to use
MultiValidator:
final IObservableSet checkedElements =
ViewersObservables.observeCheckedElements(checkboxTable);
MultiValidator notEmptyValidator = new MultiValidator() {
protected IStatus validate() {
if (checkedElements.isEmpty())
return ValidationStatus.error("Please select at least one item");
return ValidationStatus.ok();
dbc.addValidationStatusProvider(notEmptyValidator);
dbc.bindSet(
notEmptyValidator.observeValidatedSet(checkedElements),
myModelSet,
null,
null);
Matthew
Marcelo Alcantara wrote:
> Marcelo Alcantara
Re: [Databinding] Validating at least one selection in a Checkbox Table Viewer [message #334077 is a reply to message #333887] Mon, 19 January 2009 08:24 Go to previous message
Originally posted by: malloovidio.bluewin.ch
Actually, there already is a bug report for adding validation to
collection bindings:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=168225
Doing so might be a bit tricky since validation probably leads
to the target/model collections getting out of sync.
Ovidio
> MultiValidator:
> dbc.bindSet(
> myModelSet,
> null,
> null);
> Matthew
>> single item is selected in a checkbox table viewer.
>> could not find a nice solution to this.
>> it does not cover all required validation situations (like when the
>> view/form is first opened, before selecting or deselecting anything
>> from the list).
>> have an urgent requirement for this on the current project. Trying to
>> consolidate the rcp platform here.
>> Marcelo Alcantara
Previous Topic:Z-Order of Windows
Next Topic:Custom ISelectionProvider and checkEnabled for Visibility of commands does not work properly
Current Time: Sun Jul 27 11:07:19 EDT 2025
Powered by FUDForum. Page generated in 0.04033 seconds
