| why does the jvm terminate when i open eclipse? [message #333870] |
Sun, 11 January 2009 14:44  |
Originally posted by: automatic.javalobby.org
just downloaded eclipse and it gets terminated with jvm error codes, i first tried it with java 6, and switched back to java 5, and played with permMaxSize
this happened also with europa-winter.
| Re: why does the jvm terminate when i open eclipse? [message #333881 is a reply to message #333873] |
Mon, 12 January 2009 09:04  |
On 1/11/2009 3:46 PM, Ed Merks wrote:
> Elhanan,
> What are you doing to ensure that a specific JRE is used? (As opposed to
> the one that happens to be the system default installed in system32.)
>> with permMaxSize
See http://wiki.eclipse.org/Eclipse.ini for how to specify the JVM and
memory parameters.
Hope this helps,
Eric
FUDForum. Page generated in 0.03501 seconds
