Home » Eclipse Projects » Eclipse Platform » Contribute command menu item to "legacy" menu?
Contribute command menu item to "legacy" menu? [message #333850] Fri, 09 January 2009 07:27 Go to next message
I need to put a command handler menu item (using org.eclipse.ui.menus
extension point) to a menu created by another plugin using
org.eclipse.ui.actionSets.
I can't figure out a proper URI. Lets say another plugin contributes to
the location I need using following menubarPath -
com.xyz.menu/someSeparator. What would be the matching URI? I tried both
menu:com.xyz.menu and menu:org.eclipse.ui.main.menu/com.xyz.menu with no
effect.
Eugene
Re: Contribute command menu item to "legacy" menu? [message #333882 is a reply to message #333850] Mon, 12 January 2009 10:37 Go to previous message
You would have to replicate the menu structure in your
org.eclipse.ui.menus and place the command in it.
actionSets can see o.e.ui.menus menu structure, but no one can see menus
defined in actionSets (not even other actionSets)
PW
Paul Webster
Previous Topic:why does the jvm terminate when i open eclipse?
Next Topic:How to create nested default editor for MultiPageEditorPart?
Current Time: Wed Nov 05 06:51:10 EST 2025
Powered by FUDForum. Page generated in 0.15012 seconds
