Home » Eclipse Projects » Eclipse Platform » How can I increase heap and permanent memory
How can I increase heap and permanent memory [message #333845] Thu, 08 January 2009 14:23 Go to next message
I can increase memory for Eclipse GANYMEDE, I have tried this manual:
http://wiki.eclipse.org/IRC_FAQ#I.27m_having_memory.2C_heap. 2C_or_permgen_problems.2C_what_can_I_do.3F
My eclipse.ini looks like this:
-startup
plugins\org.eclipse.equinox.launcher_1.0.101.R34x_v20080819. jar
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
512m
-vmargs
-Xms128m
-Xmx384m
-XX:PermSize=256M
And here the problem is, I can't increase memory XXMaxPermSize more than 512m and heap
memory can't increase more than -Xmx384m
When I increase memory I get this error if I start GANYMEDE:
http://tinyurl.com/8wwgz6
My OS WinXP SP2 4GB Ram. Where the problem could be ?
Thank you for any advices.
Re: How can I increase heap and permanent memory [message #333847 is a reply to message #333845] Fri, 09 January 2009 01:47 Go to previous messageGo to next message
"sNop" <snop3@seznam.cz> wrote in message
news:gk5jrc$8ma$1@build.eclipse.org...
> -startup
> -showsplash
> 512m
> -vmargs
> -Xms128m
> -Xmx384m
> -XX:PermSize=256M
> 512m and heap
Let's start with the basics. Why do you need more memory? And in
particular, why do you need more permgen space? 512M for permgen is HUGE,
you should not need that much. Precisely what is the problem that you are
trying to solve?
Also, what JVM version are you using?
Re: How can I increase heap and permanent memory [message #333848 is a reply to message #333847] Fri, 09 January 2009 05:41 Go to previous messageGo to next message
Walter Harley napsal(a):
> trying to solve?
My problem is, that Eclipse take over 200MB when I use it whole day. And some things stop
work during, as is code assist in PDT, when I restart eclipse it hangs, windows is closed
but he is still in memory
So I have tried increas memory heap and I can't My JVM is java version "1.6.0_11"
Java(TM) SE Runtime Environment (build 1.6.0_11-b03)
Java HotSpot(TM) Client VM (build 11.0-b16, mixed mode, sharing)
I have lot of ram so 256m which is reserved for eclipse is less, but i can't increase
because the error as I described above
Re: How can I increase heap and permanent memory [message #333849 is a reply to message #333848] Fri, 09 January 2009 05:56 Go to previous messageGo to next message
sNop napsal(a):
>> trying to solve?
E.g. now i'm working few minutes, my eclipse ini looks like this:
-showsplash
256m
-vmargs
-Xms40m
-Xmx256m
But in memory it have 300MB
Re: How can I increase heap and permanent memory [message #333852 is a reply to message #333849] Fri, 09 January 2009 09:18 Go to previous messageGo to next message
> -showsplash
> 256m
> -vmargs
> -Xms40m
> -Xmx256m
Apparently you don't understand how memory is used and managed by the
JVM process. Heap space makes up only a portion of the total memory used
by the JVM (or any process, not just Java). There is lots of other
memory used outside of heap and that is why you see the OS reporting
more memory usage by the process than the size of your heap.
I also agree with Walter that PermGen space should definitely not need
to be higher than 256M - I've worked on some huge applications,
including Eclipse-based development tools and enterprise server apps,
and NONE of them has ever needed permgen more than 256M.
Also, your eclipse.ini does not specify the JVM, which it should. See
http://wiki.eclipse.org/Eclipse.ini for information on how to use the
-vm option.
Finally, there is a limitation of the JVM on Windows that can prevent it
from allocating very large memory sizes (both heap and PermGen). If you
set the values for them too high, Windows can fails to allocate space.
The details are rather complicated, but all you really need to
understand is that it is not advisable to set your memory settings
arbitrarily high; only as high as you really need.
Hope this helps,
Eric
Re: How can I increase heap and permanent memory [message #333859 is a reply to message #333849] Fri, 09 January 2009 15:26 Go to previous messageGo to next message
news:gk7aft$1v6$1@build.eclipse.org...
> -showsplash
> 256m
> -vmargs
> -Xms40m
> -Xmx256m
For what it's worth, those are the same settings I have (they're the
defaults) and I am able to do Java development all day without any problems.
So I wonder if there is a different problem affecting you, not just memory.
I would leave the permgen space alone, don't change that. If you are
running out of permgen space you will get a message that says so.
And if you edit that eclipse.ini, ONLY changing the -Xmx256m line
to -Xmx512m, making no other changes, do you still get the error you
reported before?
Re: How can I increase heap and permanent memory [message #333860 is a reply to message #333859] Fri, 09 January 2009 15:39 Go to previous message
>> -showsplash
>> 256m
>> -vmargs
>> -Xms40m
>> -Xmx256m
> reported before?
thank you, if i change only Xmx, so it works, i think that 512m for heap is sufficient
thank you
Previous Topic:How do I add toolbar actions to a specific ContentOutline page
Next Topic:Listening to File saves
Current Time: Sat Aug 30 06:19:20 EDT 2025
Powered by FUDForum. Page generated in 0.03635 seconds
