Home » Eclipse Projects » Eclipse Platform » ColumnLabelProvider reusable ?
ColumnLabelProvider reusable ? [message #333821] Wed, 07 January 2009 11:15 Go to next message
Originally posted by: rune.molin.cph.dk
I was looking into how to provide a tooltip for an entire row in a
tableviewer for an RCP app i'm working on when I came across the new
(as of 3.3) API of ColumnLabelProvider, TableViewerColumn etc.
Google found me some articles explaining why this is a good thing
because you could reuse a labelprovider, for example like this:
public class StockValueProvider extends ColumnLabelProvider {
public String getText(Object element) {
return ((Stock)element).modification.doubleValue() + "%";
Now, what I don't get is why this is supposed to be reusable in any
relevant way - The way I see it, the only case you can use this
StockValueProvider is when you have a public "modification" attribute in
a Stock class. What if this modification attribute is a member of
another class, but I still want it displayed with a percentage sign
appended. Then I write another label provider ? Am I missing something
obvious here ?
So anyway, how do you implement a tooltip that pertains to the entire
row, and not just one column :0)
-- Cheers
Rune Molin
Software Developer
Copenhagen Airports
Re: ColumnLabelProvider reusable ? [message #333823 is a reply to message #333821] Wed, 07 January 2009 11:27 Go to previous messageGo to next message
Hi Rune,
Take a look at
http://www.eclipse.org/newsportal/article.php?id=34342&g roup=eclipse.platform.rcp#34342
.. I included an example implementation of ColumnLabelProvider which can
access arbitary values.
So now to your ToolTip-Question. To enabled row-tooltips you should
overload ColumnLabelProvider#getToolTipText() and return the same value
of the based upon the model object the tooltip occurs on naturally you
could also add a generic solution like the one shown above.
Tom
> @Override
> obvious here ?
> -- Cheers
> Rune Molin
> Software Developer
> Copenhagen Airports
Re: ColumnLabelProvider reusable ? [message #333833 is a reply to message #333823] Wed, 07 January 2009 17:28 Go to previous messageGo to next message
Originally posted by: rune.molin.gmail.com
Hi Tom,
Ah - Very clever. My experience in generics is not that extensive, but wont
new DelegatingColumnLabelProvider(
new DelegateAccessor<Author, BigDecimal)() {
result in a ClassCastException when
return delegateAccessor.getValue(element);
gets called ?
Tom Schindl wrote:
> Hi Rune,
> Take a look at
Re: ColumnLabelProvider reusable ? [message #333835 is a reply to message #333833] Wed, 07 January 2009 17:54 Go to previous message
Hi Rune,
Rune Molin schrieb:
> Hi Tom,
Sure as you noticed I invented this while writing the mail so you should
check for null and then call .toString().
Tom
Previous Topic:to Platform Debug experts
Next Topic:Feature not displayed
Current Time: Sat Jul 26 07:09:13 EDT 2025
Powered by FUDForum. Page generated in 0.13432 seconds
