Home » Eclipse Projects » Eclipse Platform » object contribution action and key shortcut ...
object contribution action and key shortcut ... [message #333820] Wed, 07 January 2009 10:26 Go to next message
Hi all
I have got few views that displays actions in popup coming from object
contribution ...
I was wondering if it is possible to bind key to this action (for example
the delete to the delete action).
Thanks for any help
Kar
Re: object contribution action and key shortcut ... [message #333843 is a reply to message #333820] Thu, 08 January 2009 10:17 Go to previous message
ObjectContributions can't be bound to keys.
On way to do this would be to create a command/handler combo that works
on the activeMenuSelection and the current selection if that's not
available. Then you can bind that command to a key and use
org.eclipse.ui.menus with a locationURI of
popup:org.eclipse.ui.popup.any to add it to popup menus, and the
menuContribution/command element can have a visibleWhen clause (to make
it similar to an object contribution)
Later,
PW
Paul Webster
Previous Topic:[p2] Eclipse 3.5 M4 - potential bug
Next Topic:Exception when doing drag-drop into a Texteditor
Current Time: Fri Jul 18 10:17:26 EDT 2025
Powered by FUDForum. Page generated in 0.04118 seconds
