Home » Eclipse Projects » Eclipse Platform » Eclipse crashes after having started with the -clean option
Eclipse crashes after having started with the -clean option [message #333767] Sun, 04 January 2009 11:01
Originally posted by: inancaytac78.gmail.com
Hi all,
Since I have started my Eclipse (Ganymede) with -clean, the workspace, I
have been working in, cannot be loaded.
I see the splash screen, choose my workspace but afterwards Eclipse
crashes with following complaints:
!SESSION ...
eclipse.buildId=M20080911-1700
java.version=1.6.0_05
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -consoleLog -debug
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2009-01-04 16:28:38.793
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Import-Package:
org.eclipse.equinox.internal.provisional.configurator; version="0.0.0"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:489)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:321)
Has anybody any clue why this happens? (loading other workspaces works
fine but I have been trying to open my last used workspace to no avail.
Or has anybody any clue where I should look for the cause?
Thanks in advance for any hint / help
inanc
Previous Topic:artifacts.xml file is misplaced when using -configuration parameter
Next Topic:LinkedResources for resources with same name
Current Time: Wed Oct 15 11:48:32 EDT 2025
Powered by FUDForum. Page generated in 0.04599 seconds
