Home » Eclipse Projects » Eclipse Platform » Tables and Checkboxes
| Tables and Checkboxes [message #333750] |
Wed, 31 December 2008 13:44  |
I have a table that I have created like the following:
Table table (myComposite, SWT.BORDER | SWT.MULTI);
// Make the columns
for (int i=0; i<6, i++){
TableColumn column = new TableColumn(table, SWT.NONE);
//Make the rows
for(int k=0; k<myArrayList.size(); k++){
new TableItem(table, SWT.NONE);
TableItem[] items = table.getItems();
for(int j=0; j<items.length; j++){
TableEditor editor = new TableEditor(table);
Button button = new Button(table, SWT.CHECK);
button.setText(myArrayList.get(j).toString());
button.pack();
editor.setEditor(button, items[j], 0);
Button button2 = new Button(table, SWT.CHECK);
button2.setText(anotherArrayList.get(j).toString());
button2.pack();
editor.setEditor(button2, items[j], 1);
This displays how I would like it to display, basically a big 2 d array of
checkboxes. The issue that I am having is how do I go back into the table
to see what checkboxes have been checked and what ones haven't? I can't
seem to figure out how I would do that. To give it context, this grid is
going to display permissions for users and groups.
If there is a better way of creating a table or displaying a grid of
checkboxes and then managing their state please let me know. Thanks!
Andy
| Re: Tables and Checkboxes [message #333755 is a reply to message #333750] |
Fri, 02 January 2009 06:55   |
You better use a TableViewer and emulated checkboxes because this
reduces the amount of memory and you have then backed up your states in
a model element.
Take a look at
http://wiki.eclipse.org/Tables_And_Trees_And_NativeControls
Tom
> // Make the columns
> //Make the rows
> button.pack();
> button2.pack();
> of checkboxes. The issue that I am having is how do I go back into the
> table to see what checkboxes have been checked and what ones haven't? I
> can't seem to figure out how I would do that. To give it context, this
> grid is going to display permissions for users and groups.
> Andy
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: Tables and Checkboxes [message #333779 is a reply to message #333755] |
Mon, 05 January 2009 10:59   |
Thanks for the info. I took a look at
I am still confused as to which option you are referred to as "emulated
checkboxes" because it seemed like all those articles had to do with
displaying items in a table and item visibility, not capturing the values
of the checkboxes. I can display all the items just fine with the current
code.
Was there an option out of the 5 on that page that covered this question?
I looked at them but didn't seem to find any.
Do you know of an example that displays multiple checkboxes in a table and
also has code to track the state of all of them? Thanks.
Andy
Tom Schindl wrote:
> a model element.
> Take a look at
> Tom
>> // Make the columns
>> //Make the rows
>> button.pack();
>> button2.pack();
>> Andy
| Re: Tables and Checkboxes [message #333780 is a reply to message #333779] |
Mon, 05 January 2009 11:33   |
Well if you take:
a) http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet056BooleanCellEditor.java?view=markup
and
b) http://tom-eclipse-dev.blogspot.com/2007/01/tableviewers-and -nativelooking.html
You are best of when checking out the code from the cvs-repository.
Tom
> values of the checkboxes. I can display all the items just fine with
> the current code.
> question? I looked at them but didn't seem to find any.
> and also has code to track the state of all of them? Thanks.
> Andy
> Tom Schindl wrote:
>> a model element.
>> Take a look at
>> Tom
>>> // Make the columns
>>> //Make the rows
>>> button.pack();
>>> button2.pack();
>>> grid is going to display permissions for users and groups. If there
>>> Andy
| Re: Tables and Checkboxes [message #333783 is a reply to message #333780] |
Mon, 05 January 2009 15:45   |
Thanks for the response.
Maybe I am doing something wrong or not asking a specific enough question,
but I still can't find any example as to how you go back and scan through
all the checkboxes. From what I can see these examples show how to
*display* the checkboxes. That isn't the problem as I can display them
without any issue. It seems like these examples are fixes to some kind of
bug in displaying a checkbox in a column other than the first one in a
table. I have no issue displaying the checkboxes in any column. All I
want to do is basically iterate over a 2 D array and check to see if a
particular checkbox (really a button) got checked or not.
I would like to do something like this:
TableItem[] updatedTableItems = table.getItems();
for(int k=0; k<updatedTableItems.length; k++){
for(int i=0; i<table.getColumnCount(); i++){
Button b = /* getButton at index [k][i] in the table */;
What would go in the /* */ area? table doesn't seem to give me methods
that I can feed a row and a column index to and pull out the Button stored
there. Thanks for your help.
Andy
Tom Schindl wrote:
> Well if you take:
> and
> Tom
>> the current code.
>> Andy
>> Tom Schindl wrote:
>>> Hi,
>>> a model element.
>>> Take a look at
>>> Tom
>>>> // Make the columns
>>>> //Make the rows
>>>> button.pack();
>>>> button2.pack();
>>>> Andy
| Re: Tables and Checkboxes [message #333788 is a reply to message #333783] |
Mon, 05 January 2009 17:08   |
Hi Andy,
What I'm trying to teach you is that you should use a Viewer with a
CellEditor a JFaceViewer is backed up by object-model.
Let's suppose you have a TableViewer like this:
|File | Read | Write | Execute |
| A.exe | x | x | x |
| A.html | x | x | |
As a model element you would have a class like this:
class File {
public String name;
public boolean read;
public boolean write;
public boolean execute;
public File(String name) {
this.name = name;
=> To show a table like the one above you need 2 instances
List<File> files = new ArrayList<File>();
files.add(new File("A.exe"));
files.add(new File("A.html"));
The CellEditor allows you to edit boolean values and magically update
the underlying model which means with a JFace-Viewer both your model
elements(=File-Attributes) and your view (=Cell-Values) are kept in sync
automatically with the benefit that you get sorting, fitering and
smoother scrolling for free. So with a viewer you don't need to go back
and scan the viewer because you simply look at your model element and
are done.
Tom
> question, but I still can't find any example as to how you go back and
> scan through all the checkboxes. From what I can see these examples
> show how to *display* the checkboxes. That isn't the problem as I can
> display them without any issue. It seems like these examples are fixes
> to some kind of bug in displaying a checkbox in a column other than the
> first one in a table. I have no issue displaying the checkboxes in any
> column. All I want to do is basically iterate over a 2 D array and
> check to see if a particular checkbox (really a button) got checked or not.
> for(int k=0;
> methods that I can feed a row and a column index to and pull out the
> Button stored there. Thanks for your help.
> Andy
> Tom Schindl wrote:
>> Well if you take:
>> and
>> Tom
>>> the current code. Was there an option out of the 5 on that page that
>>> covered this
>>> Andy
>>> Tom Schindl wrote:
>>>> Hi,
>>>> a model element.
>>>> Take a look at
>>>> Tom
>>>>> // Make the columns
>>>>> //Make the rows
>>>>> button.pack();
>>>>> button2.pack();
>>>>> array
>>>>> the
>>>>> haven't? I
>>>>> this
>>>>> Andy
| Re: Tables and Checkboxes [message #333801 is a reply to message #333788] |
Tue, 06 January 2009 10:46   |
Tom,
Thanks for your patience in answering all my questions. The part that is
giving me trouble is I don't understand why if I can put the checkboxes
into the table directly, why I can't pull them back out directly. That
just seems odd to me based on the code I have below when it seems like I
should just need to do a one line method call to get the button based on
the position of the array.
It seems like I am forced into using several layers of abstraction, like
the Table plus
a LabelProvider,
a Viewer,
a Content Provider,
a BooleanCellEditor,
and possibly others.
I can find bits and pieces of examples that do something similar all over
the web, but none that are end to end examples that integrate all the
pieces together.
I gather that you are saying I should model each row of the table in an
object. No problem, I can do that. So if I was going to do that, would I
have a table which pointed to a viewer which would then hold that array of
files and then also hook the cell editor to the table? How would the cell
editor map to each boolean value in the file model?
Using the original table below as a start, if you have a simple example of
the java files that show the relationships I can take that and write an
article on it and post it so that others who run into this problem can use
it as a reference.
Sorry for me to be so clueless on the subject. Thanks,
Andy
Tom Schindl wrote:
> Hi Andy,
> | A.exe | x | x | x |
> | A.html | x | x | |
> class File {
> public String name;
> this.name = name;
> are done.
> Tom
>> for(int k=0;
>> Andy
>> Tom Schindl wrote:
>>> Well if you take:
>>> and
>>> Tom
>>>> covered this
>>>> Andy
>>>> Tom Schindl wrote:
>>>>> Hi,
>>>>> a model element.
>>>>> Take a look at
>>>>> Tom
>>>>>> // Make the columns
>>>>>> //Make the rows
>>>>>> button.pack();
>>>>>> button2.pack();
>>>>>> array
>>>>>> the
>>>>>> haven't? I
>>>>>> this
>>>>>> Andy
| Re: Tables and Checkboxes [message #333803 is a reply to message #333801] |
Tue, 06 January 2009 11:42   |
Go and checkout https://bugs.eclipse.org/bugs/show_bug.cgi?id=260061 it
holds a code snippet which is exactly what you are looking for.
I didn't committed the code yet because I merged in contributions from
people who commented on my blog.
I'm not 100% satisfied because the cell-editor background is not
transparent and I've only tested on OS-X.
Tom
Andy schrieb:
> Tom,
> is giving me trouble is I don't understand why if I can put the
> checkboxes into the table directly, why I can't pull them back out
> directly. That just seems odd to me based on the code I have below when
> it seems like I should just need to do a one line method call to get the
> button based on the position of the array.
> the Table plus
> a LabelProvider, a Viewer, a Content Provider, a BooleanCellEditor, and
> possibly others.
> over the web, but none that are end to end examples that integrate all
> the pieces together.
> I have a table which pointed to a viewer which would then hold that
> array of files and then also hook the cell editor to the table? How
> would the cell editor map to each boolean value in the file model?
> of the java files that show the relationships I can take that and write
> an article on it and post it so that others who run into this problem
> can use it as a reference.
> Andy
> Tom Schindl wrote:
>> Hi Andy,
>> | A.exe | x | x | x |
>> | A.html | x | x | |
>> class File {
>> public String name;
>> this.name = name;
>> are done.
>> Tom
>> Andy schrieb:
>>> Thanks for the response. Maybe I am doing something wrong or not
>>> or not.
>>> for(int k=0;
>>> } } What
>>> Andy
>>> Tom Schindl wrote:
>>>> Well if you take:
>>>> and
>>>> Tom
>>>>> "emulated
>>>>> covered this
>>>>> Andy
>>>>> Tom Schindl wrote:
>>>>>> Hi,
>>>>>> states in
>>>>>> a model element.
>>>>>> Take a look at
>>>>>> Tom
>>>>>>> // Make the columns
>>>>>>> //Make the rows
>>>>>>> button.pack();
>>>>>>> button2.pack();
>>>>>>> array
>>>>>>> the
>>>>>>> haven't? I
>>>>>>> this
>>>>>>> Thanks!
>>>>>>> Andy
| Re: Tables and Checkboxes [message #333822 is a reply to message #333803] |
Wed, 07 January 2009 11:23   |
Tom,
I took a look at Snippet061FakedNativeCellEditor - thanks. One of the
things I have been trying to figure out is why does the example use a
treeviewer and not a tableviewer? I can't seem to find a tableviewer
anywhere yet the example obviously is in a table.
I see that the File Object is the model that holds all the files and their
properties. That definitely made the model concept more clear.
I changed the first column in the table to display a field in the File
mode, something simple like a filename, but I notice that I can only see
that when I click on it and instead see the tree information by default in
that column. Is there a way to disable that for the first column so that
I just see the filename?
Andy
Tom Schindl wrote:
> Tom
> Andy schrieb:
>> Tom,
>> the Table plus
>> possibly others.
>> Andy
>> Tom Schindl wrote:
>>> Hi Andy,
>>> | A.exe | x | x | x |
>>> | A.html | x | x | |
>>> class File {
>>> public String name;
>>> this.name = name;
>>> are done.
>>> Tom
>>>> or not.
>>>> for(int k=0;
>>>> } } What
>>>> Andy
>>>> Tom Schindl wrote:
>>>>> Well if you take:
>>>>> and
>>>>> Tom
>>>>>> "emulated
>>>>>> covered this
>>>>>> Andy
>>>>>> Tom Schindl wrote:
>>>>>>> Hi,
>>>>>>> states in
>>>>>>> a model element.
>>>>>>> Take a look at
>>>>>>> Tom
>>>>>>>> // Make the columns
>>>>>>>> //Make the rows
>>>>>>>> button.pack();
>>>>>>>> button2.pack();
>>>>>>>> array
>>>>>>>> the
>>>>>>>> haven't? I
>>>>>>>> this
>>>>>>>> Thanks!
>>>>>>>> Andy
| Re: Tables and Checkboxes [message #333824 is a reply to message #333822] |
Wed, 07 January 2009 11:45  |
s/Table/Tree and use an ordinary IStructuredContentProvider. The Snippet
uses a TreeViewer because I copied another Snippet to get started.
TreeViewer and TableViewer work 100% the same. I'm just working on some
fixes because OwnerDrawLabelProvider and FocusCellHighlighter seem to be
incorrect on Win32.
Tom
Andy schrieb:
> Tom,
> their properties. That definitely made the model concept more clear.
> in that column. Is there a way to disable that for the first column so
> that I just see the filename?
> Andy
> Tom Schindl wrote:
>> Tom
>> Andy schrieb:
>>> Tom,
>>> the Table plus
>>> possibly others. I can find bits and pieces of examples that do
>>> the pieces together. I gather that you are saying I should model each
>>> Andy
>>> Tom Schindl wrote:
>>>> Hi Andy,
>>>> | A.exe | x | x | x |
>>>> | A.html | x | x | |
>>>> class File {
>>>> public String name;
>>>> this.name = name;
>>>> sync
>>>> are done.
>>>> Tom
>>>>> fixes
>>>>> the
>>>>> any
>>>>> or not.
>>>>> for(int k=0;
>>>>> } } What
>>>>> Andy
>>>>> Tom Schindl wrote:
>>>>>> Well if you take:
>>>>>> and
>>>>>> Tom
>>>>>>> "emulated
>>>>>>> with
>>>>>>> covered this
>>>>>>> table
>>>>>>> Andy
>>>>>>> Tom Schindl wrote:
>>>>>>>> Hi,
>>>>>>>> states in
>>>>>>>> a model element.
>>>>>>>> Take a look at
>>>>>>>> Tom
>>>>>>>>> // Make the columns
>>>>>>>>> //Make the rows
>>>>>>>>> button.pack();
>>>>>>>>> button2.pack();
>>>>>>>>> array
>>>>>>>>> into
>>>>>>>>> the
>>>>>>>>> haven't? I
>>>>>>>>> this
>>>>>>>>> there
>>>>>>>>> Thanks!
>>>>>>>>> Andy
Current Time: Sat Nov 08 12:30:16 EST 2025
Powered by FUDForum. Page generated in 0.04687 seconds
