| Deselecting a combo with JFace Databinding [message #333733] |
Tue, 30 December 2008 08:24  |
What is the best way to clean a combo or comboviewer with databinding
setting the model value? There is a good snipet for it somewhere? I searched
the snippets and examples and could not find anything.
Actually, using a ComboViewer, I am just able to do this calling the
deselectAll method. If I set the variable on the model to -1 (out of range
values) it is not working.
Thanks for any help.
Marcelo
| Re: Deselecting a combo with JFace Databinding [message #333797 is a reply to message #333740] |
Tue, 06 January 2009 07:35  |
Tom/Eric,
Thanks.
I was making the bind with the combo widget (inside the combo viewer) and
not the combo viewer itself. I changed to use the
ViewerObservable.observeSingleSelection and the set(null) cleared the combos
without problems.
Marcelo
"Tom Schindl" <tom.schindl@bestsolution.at> escreveu na mensagem
news:gjdban$qad$1@build.eclipse.org...
> Or setting the ComboViewer-Selection to StructuredSelection.EMPTY.
> Tom
> Eric Rizzo schrieb:
>> On 12/30/2008 8:24 AM, Marcelo Alcantara wrote:
>>> Hi,
>>> searched
>>> range
>> I would try setting the model value to null.
>> Hope this helps,
>> Eric
> B e s t S o l u t i o n . at
> Tom Schindl JFace-Committer
FUDForum. Page generated in 0.03669 seconds
