Home » Eclipse Projects » Eclipse Platform » how to read my plugin dependency libraries
how to read my plugin dependency libraries [message #333726] Mon, 29 December 2008 07:09 Go to next message
Hi All,
I am having a common problem of reading the reference libraries.
Examle --
1)I am having a plugin project named as -com.example1
2)I am having another plugin -com.example2
3)Plugin-com.example2 is dependent on plugin-com.example1
4)i have added c.jar to the com.example1 plugin an the build path
3)plugin-com.example1 has exported some packages of the c.jar
in manifest.mf files
4)Plugin-com.example2 has imported those packages in manifest
file.
How to get all the class names resides in that package in the
plugin-com.example2 programmatically to load the class through reflection
class.forname(packagename.classname).because i want to access all the
methods of those classes.
Thanks in advance
Debasis
Re: how to read my plugin dependency libraries [message #333727 is a reply to message #333726] Mon, 29 December 2008 07:15 Go to previous message
Debasis,
Please don't cross post the same question to multiple newsgroups. This
question was already addressed in the newscomer newsgroup before you
posted it here too...
Debasis Mishra wrote:
> Hi All,
> Examle --
> path
> c.jar in manifest.mf files
> manifest file.
> reflection class.forname(packagename.classname).because i want to
> access all the methods of those classes.
> Thanks in advance
> Regards
> Debasis
Previous Topic:Check out the complete source code package for Eclipse Platform by SVN
Next Topic:Resource Change Listener via XML?
Current Time: Mon Sep 01 02:32:59 EDT 2025
Powered by FUDForum. Page generated in 0.03127 seconds
