Home » Eclipse Projects » Eclipse Platform » Memory consumption of virtual TableViewers
Memory consumption of virtual TableViewers [message #333721] Mon, 29 December 2008 05:42 Go to next message
Hi all,
I have in my app a virtual TableViewer (SWT.VIRTUAL) that shows a lot of
items.
My custom ILazyContentProvider doesn't maintain all the items, it fetches
on the fly from a database as needed.
Theorically the memory consumption of my app would be very low,
independent from the number of rows.
But empirically, the memory consumption increases a lot as the number of
rows increases. I have investigated a little with the MAT tool
(http://www.eclipse.org/mat/), and I get that the TableViewer component is
holding for a TableViewer with 15403 rows this numbers:
15403 org.eclipse.swt.widgets.TableItem's which holds 6 Mb of memory
23006 int[]'s
40325 String's with over 2 Mb memory
I need to display over 1,000,000 rows, so TableViewer's aren't scalable.
Is it possible to optimize the memory somehow?
Thanks in advance for any valuable tip.
Re: Memory consumption of virtual TableViewers [message #333722 is a reply to message #333721] Mon, 29 December 2008 05:51 Go to previous messageGo to next message
Hi David,
Short answer - no. Virtual only means that the items are not created at
once but only when they are scrolled into view but they won't get
collected once they are scrolled out of view.
Maybe something like a paging table could solve this issue.
Tom
David Pérez schrieb:
> Hi all,
> items.
> fetches on the fly from a database as needed.
> is holding for a TableViewer with 15403 rows this numbers:
> 23006 int[]'s
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Memory consumption of virtual TableViewers [message #333723 is a reply to message #333721] Mon, 29 December 2008 05:58 Go to previous messageGo to next message
Further investigation:
public class Table {
TableItem [] items; // <--- This is the guilty of memory excesive use
// This is where the items are created and never released....
TableItem _getItem (int index) {
if ((style & SWT.VIRTUAL) == 0) return items [index];
if (items [index] != null) return items [index];
return items [index] = new TableItem (this, SWT.NONE, -1, false);
Maybe this is a topic for the SWT newsgroup.
I'll post there.
David Pérez wrote:
> Hi all,
> items.
> 23006 int[]'s
Re: Memory consumption of virtual TableViewers [message #333724 is a reply to message #333722] Mon, 29 December 2008 06:01 Go to previous messageGo to next message
Thanks Tom for your quick answer. :-)
Do you consider is it easy to implement such a paging table?
Does anybody know a Table replacement?
Tom Schindl wrote:
> Hi David,
> Tom
Re: Memory consumption of virtual TableViewers [message #333725 is a reply to message #333722] Mon, 29 December 2008 06:07 Go to previous messageGo to next message
I'm going to study this a little more and let you know of any advances.
If I manage to solve this problem, my intention is to share my code with
this newsgroup.
David
Tom Schindl wrote:
> Hi David,
> Tom
Re: Memory consumption of virtual TableViewers [message #333730 is a reply to message #333724] Tue, 30 December 2008 04:09 Go to previous message
Here is my solution that works:
public class PagedTable extends Table {
int[] selectedIndices;
public PagedTable(Composite parent, int style) {
super(parent, style | SWT.VIRTUAL);
private void freeUnusedItems(Widget ignoreItem) {
if (items.length > 0) {
int[] range = getVisibleRange();
selectedIndices = getSelectionIndices();
for (int i = 0; i < range[0]; i++) {
releaseItem(i, ignoreItem);
for (int i = range[1]+1; i < items.length; i++) {
private void releaseItem(int i, Widget ignoreItem) {
if (items[i] != null && items[i] != ignoreItem) {
for (int j = 0; j < selectedIndices.length; j++) {
// No liberar elementos seleccionados
if (selectedIndices[j] == i) {
return;
if (!items[i].isDisposed()) {
items[i].release(false);
items[i] = null;
public int[] getVisibleRange() {
int[] res = new int[2];
int height = getItemHeight();
int totalHeight = getSize().y;
if (getHeaderVisible()) {
totalHeight -= getHeaderHeight();
res[0] = getTopIndex();
res[1] = res[0]+(totalHeight+height-1)/height-1;
return res;
@Override TableItem _getItem(int index) {
TableItem res = super._getItem(index);
freeUnusedItems(res);
return res;
@Override void postEvent(int eventType, Event event) {
super.postEvent(eventType, event);
if (eventType == SWT.SELECTED) {
freeUnusedItems(event.item);
This class must be placed in the existing org.eclipse.swt plugin, as
Eclipse doesn't ease the expandibility of builtin classes in any other way.
I hope this will be useful to someone else.
> Tom Schindl wrote:
>> Hi David,
>> Tom
Previous Topic:Resource Change Listener via XML?
Next Topic:Perform project updates during/post plugin update
Current Time: Wed Nov 19 14:46:42 EST 2025
Powered by FUDForum. Page generated in 0.05051 seconds
