Home » Eclipse Projects » Eclipse Platform » javadoc cannot be showed correctly
javadoc cannot be showed correctly [message #333659] Sat, 20 December 2008 22:31 Go to next message
Originally posted by: reg.zhuce.163.com
It always shows lots of css on top.How to show javadoc
directly(i.e.,without css as follow)?
/* Font definitions */ html { font-family:
'Tahoma',sans-serif; font-size: 10pt; font-style:
normal; font-weight: normal; } body, h1, h2, h3, h4,
h5, h6, p, table, td, caption, th, ul, ol, dl, li, dd, dt
{ font-size:1em; } pre { font-family: monospace; } /*
Margins */ body { overflow: auto; margin-top: 0px;
margin-bottom: 0.5em; margin-left: 0.3em; margin-
right: 0px; } h1 { margin-top: 0.3em; margin-bottom:
0.04em; } h2 { margin-top: 2em; margin-bottom:
0.25em; } h3 { margin-top: 1.7em; margin-bottom:
0.25em; } h4 { margin-top: 2em; margin-bottom:
0.3em; } h5 { margin-top: 0px; margin-bottom:
0px; } p { margin-top: 1em; margin-bottom: 1em; }
pre { margin-left: 0.6em; } ul { margin-top: 0px;
margin-bottom: 1em; } li { margin-top: 0px; margin-
bottom: 0px; } li p { margin-top: 0px; margin-bottom:
0px; } ol { margin-top: 0px; margin-bottom: 1em; }
dl { margin-top: 0px; margin-bottom: 1em; } dt
{ margin-top: 0px; margin-bottom: 0px; font-weight:
bold; } dd { margin-top: 0px; margin-bottom: 0px; } /
* Styles and colors */ a:link { color: #0000FF; }
a:hover { color: #000080; } a:visited { text-
decoration: underline; } h4 { font-style: italic; }
strong { font-weight: bold; } em { font-style: italic; }
var { font-style: italic; } th { font-weight: bold; }
Re: javadoc cannot be showed correctly [message #333664 is a reply to message #333659] Mon, 22 December 2008 00:12 Go to previous messageGo to next message
"dazh" <reg.zhuce@163.com> wrote in message
news:gikda4$q8m$1@build.eclipse.org...
> [...bunch of css snipped]
Can you please be much more specific about your question? From what you
posted I can't even tell if you're talking about Eclipse, let alone what
version. I certainly can't tell where you are seeing this, or how you
caused it to happen, or what you have tried to fix it.
Re: javadoc cannot be showed correctly [message #334094 is a reply to message #333664] Tue, 20 January 2009 05:05 Go to previous messageGo to next message
i've faced the same problem. It happened after i've added source code
archive for servlet-api.jar. i use ganymede 3.4.1 Build id: M20080911-1700
screenshot: http://img168.imageshack.us/img168/5262/wtffl7.jpg
Re: javadoc cannot be showed correctly [message #334097 is a reply to message #334094] Tue, 20 January 2009 11:13 Go to previous messageGo to next message
>> you posted I can't even tell if you're talking about Eclipse, let
>> alone what version. I certainly can't tell where you are seeing
>> this, or how you caused it to happen, or what you have tried to fix it.
> M20080911-1700
This is not Javadoc but some help info in a web editor. The source of
the problem seems to be a missing Browser widget.
Dani
Re: javadoc cannot be showed correctly [message #334107 is a reply to message #334097] Wed, 21 January 2009 03:23 Go to previous messageGo to next message
> Dani
yes, but this "help info in a web editor" comes from source code javadoc
comments.. but it doesnt really matter ;)
please, help me solve this problem. about that "Browser widget" are you
talking? does ganymede use IE as this browser "engine"? should i patch my
IE or add some libs to my ganymede?
Re: javadoc cannot be showed correctly [message #334108 is a reply to message #334107] Wed, 21 January 2009 05:40 Go to previous messageGo to next message
>> Dani
> javadoc comments.. but it doesnt really matter ;)
> you talking? does ganymede use IE as this browser "engine"? should i
> patch my IE or add some libs to my ganymede?
So, I assume you're on Windows? Just to verify that this is the case:
can you try whether (real) Javadoc is shown by the Java editor and in
the Javadoc view?
Dani
Re: javadoc cannot be showed correctly [message #334116 is a reply to message #334108] Wed, 21 January 2009 08:21 Go to previous messageGo to next message
> the Javadoc view?
> Dani
i've unplug sources and plug javadoc(via link to
http://java.sun.com/products/servlet/2.5/docs/servlet-2_5-mr 2/index.html).
but, unfortunately, it haven't solve my problem :(
In .java editor all works just fine.
Without jdocs and sources ganymede doesn't show anything in java editor
both in jsp editor (no wonder..)
So, it seems that the problem is in the jsp editor.
Re: javadoc cannot be showed correctly [message #334117 is a reply to message #334116] Wed, 21 January 2009 08:38 Go to previous messageGo to next message
>> the Javadoc view?
>> Dani
> editor both in jsp editor (no wonder..)
Correct, if it displays in the Java editor and in the Javadoc view then
it's not the missing Browser widget but a bug or a setup problem with
the JSP editor.
Dani
Re: javadoc cannot be showed correctly [message #334121 is a reply to message #334117] Wed, 21 January 2009 09:55 Go to previous message
> the JSP editor.
> Dani
i've looked through jsp editor options, but didn't find anything, that
could cause an error. (also i've restored default setting, but it didn't
help)
maybe u can advice me another jsp-editor?
Previous Topic:Dynamically add context help in Eclipse 3.4
Next Topic:Status Bar and setMessage
Current Time: Fri Nov 14 19:23:13 EST 2025
Powered by FUDForum. Page generated in 0.05463 seconds
