Home » Eclipse Projects » Eclipse Platform » Perform project updates during/post plugin update
Perform project updates during/post plugin update [message #333655] Fri, 19 December 2008 16:02 Go to next message
When a new version of a plugin is install, what is the suggested way to
update the plugin's associated projects?
Are there hooks/APIs that the new plugin may implement that are executed
post-install?
Thank you.
Re: Perform project updates during/post plugin update [message #333734 is a reply to message #333655] Tue, 30 December 2008 08:58 Go to previous message
> post-install?
I haven't seen any, at least not exposed through p2.
Another option would be to use your plugin
org.eclipse.core.runtime.Plugin.getStateLocation() and check for a file,
or save the information in your dialog settings if you are a UI plugin.
Then in your start(BundleContext) method you can check to see if this is
the first run, and perform your upgrades (or schedule a Job to do so).
PW
Paul Webster
Previous Topic:Memory consumption of virtual TableViewers
Next Topic:Activity id and Pattern
Current Time: Tue Jul 22 00:45:04 EDT 2025
Powered by FUDForum. Page generated in 0.04767 seconds
