Editing Manifest programmatically [message #333650] |
Fri, 19 December 2008 12:14  |
Are there any APIs for editing manifest files, for example if I wish to
add a plugin to the manifest element Require-Bundle when altering a
project nature.
Or is it just a case of reading the manifest using
org.eclipse.osgi.util.ManifestElement.parseBundleManifest(In putStream,
Map) to read and then replicating that sort of behaviour on write using
some sort of PrintWriter?
Re: Editing Manifest programmatically [message #333672 is a reply to message #333650] |
Mon, 22 December 2008 10:34  |
Doh! Using java.util.jar.Manifest seems to work ok...
For example;
public void addPluginDependency(String plugin,
String version,
boolean reexport,
boolean overwrite) throws BundleException
String requireBundleHeader = "Require-Bundle";
String bundleVersionAttr = "bundle-version";
String rexportDirective = "visibility";
assert (plugin != null);
if(plugin == null)
return;
if(version == null)
version = "1.0.0";
boolean foundHeader = false;
boolean hasValuesForPlugin = false;
StringBuilder strBuilder = new StringBuilder();
Attributes mainAttrs = manifest.getMainAttributes();
for (Object entryName : mainAttrs.keySet())
String values;
String header;
//Get the values safely
if(entryName instanceof String)
header = (String) entryName;
values = mainAttrs.getValue(header);
else if(entryName instanceof Attributes.Name)
header = (String) ((Attributes.Name) entryName).toString();
values = mainAttrs.getValue((Attributes.Name) entryName);
else
throw new BundleException("Unknown Main Attribute Key type: "
+ entryName.getClass() + " (" + entryName + ")");
//loop to the next header if we don't find ours
if(!requireBundleHeader.equals(header))
continue;
//found it
foundHeader = true;
//process the components of the value for this element see
ManifestElement javadocs for spec
if(values != null)
ManifestElement[] elements = ManifestElement.parseHeader(header,
values);
for (int i = 0; i < elements.length; i++)
ManifestElement manifestElement = elements[i];
Enumeration<?> keys = manifestElement.getKeys();
Enumeration<?> directiveKeys = manifestElement.getDirectiveKeys();
StringBuilder valueComponents = new StringBuilder();
boolean lastElement = i >= elements.length-1;
boolean firstElement = i == 0;
boolean elementIsRequiredPlugin = false;
for (int j = 0; j < manifestElement.getValueComponents().length; j++)
String pureValue = manifestElement.getValueComponents()[j];
if(plugin.equalsIgnoreCase(pureValue))
hasValuesForPlugin = true;
elementIsRequiredPlugin = true;
//if its already in the header element components and we are not
overwriting quit now
if(!overwrite)
return;
//ALWAYS WRITE THE LAST ; -> if we don't have any keys or directives
now - we will have
//if this is not the required element we will just write the line in
one go using manifestElement.getValue()
valueComponents.append(pureValue + ";");
if(!elementIsRequiredPlugin)
//we haven't got a component THIS TIME which is equal to the
component we are looking to change
//so just write out the whole of this component without editing it,
and carry on looking
strBuilder.append((firstElement?"":" ") + manifestElement.getValue()
+ (lastElement ? "" : ",\n"));
continue;
else
//write out the value components found so far - we may wish to edit
bits of it
strBuilder.append((firstElement?"":" ") + valueComponents);
boolean foundVersionAttr = false;
if(keys != null)
while (keys.hasMoreElements())
String key = (String) keys.nextElement();
String value = manifestElement.getAttribute(key);
if(bundleVersionAttr.equalsIgnoreCase(key))
//always write the last ; if we are editing the values - we will
be writing the export directive
strBuilder.append(key + "=\"" + version + "\";");
foundVersionAttr = true;
else
strBuilder.append(key + "=\"" + value + "\";");
if(!foundVersionAttr)
//always write the last ; if we are editing the values - we will be
strBuilder.append(bundleVersionAttr + "=" + version + ";");
boolean foundDirective = false;
if(directiveKeys != null)
while (directiveKeys.hasMoreElements())
String key = (String) directiveKeys.nextElement();
boolean lastDirective = !directiveKeys.hasMoreElements();
if(rexportDirective.equalsIgnoreCase(key))
foundDirective = true;
strBuilder.append(key + ":=");
String dirValues[] = manifestElement.getDirectives(key);
for (int j = 0; j < dirValues.length; j++)
String string = dirValues[j];
boolean lastDirectiveValue = j >= dirValues.length-1;
if("reexport".equalsIgnoreCase(string) && !reexport)
string = "private";
else if("private".equalsIgnoreCase(string) && reexport)
string = "reexport";
strBuilder.append(string + (lastDirectiveValue?"":","));
else
strBuilder.append(key + ":=" + manifestElement.getDirective(key));
if(!lastDirective)
strBuilder.append(";");
if(!foundDirective)
strBuilder.append(rexportDirective + ":=" +
(reexport?"rexport":"private"));
if(!lastElement)
strBuilder.append(",\n");
break;
if(!foundHeader)
//Add a new one
manifest.getMainAttributes().putValue(requireBundleHeader, plugin + ";"
+ bundleVersionAttr + "=" + version + ";" + rexportDirective + ":=" +
else if(overwrite)
//found it and wish to edit it...
if(hasValuesForPlugin)
//we have already edited the values for the plugin we wish to add
strBuilder.toString());
else
//There are no values for the plugin we wish to add.
//...create a fresh entry
String existingValues = strBuilder.toString();
boolean areExistingValues = existingValues.trim().length() != 0;
String newValue = plugin + ";" + bundleVersionAttr + "=" + version +
";" + rexportDirective + ":=" + (reexport?"rexport":"private");
newValue = (areExistingValues)?(existingValues+",\n
"+newValue):newValue;
manifest.getMainAttributes().putValue(requireBundleHeader, newValue);
public static void main(String[] args) throws Exception
try
String fileName = "C:\\Documents and
Settings\\Administrator.ARDEN\\branchWorkspace\\org.jvnet.ja xbw.eclipse\\testData\\Manifest.mf ";
ManifestChanger manifestChanger = new ManifestChanger();
FileInputStream in = new FileInputStream(fileName);
manifestChanger.loadManifest(in);
in.close();
manifestChanger.addPluginDependency("MyPlugin", "1.5.0", false, true);
FileOutputStream out = new FileOutputStream(fileName);
manifestChanger.writeManifest(out);
out.close();
catch (Throwable t)
System.err.println("Unexpected Exception: " + t);
t.printStackTrace();
FUDForum. Page generated in 0.07477 seconds
