Home » Eclipse Projects » Eclipse Platform » Specifying active Theme in plugin_customization.ini
Specifying active Theme in plugin_customization.ini [message #333626] Thu, 18 December 2008 11:30 Go to next message
we are trying to set the active theme in the plugin_customization.ini
with the key "org.eclipse.ui/CURRENT_THEME_ID", but the default theme is
always used. Our debugging efforts had no success when trying to find
out what goes wrong. Actually, our value is loaded into the preferences
store, but when the ThemeManager asks for the value, the
"org.eclipse.ui.defaultTheme" is returned.
Any ideas other than setting the theme programmatically?
Kind regards, Sebastian
Re: Specifying active Theme in plugin_customization.ini [message #333652 is a reply to message #333626] Fri, 19 December 2008 12:47 Go to previous messageGo to next message
Does your product specify your plugin_customization.ini ?
PW
Paul Webster
Re: Specifying active Theme in plugin_customization.ini [message #333670 is a reply to message #333652] Mon, 22 December 2008 09:56 Go to previous messageGo to next message
Yes it does. Other properties actually do apply.
> PW
Re: Specifying active Theme in plugin_customization.ini [message #333735 is a reply to message #333670] Tue, 30 December 2008 09:01 Go to previous messageGo to next message
If there are no errors in your error log, then you need to open a bug
against
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI
PW
Paul Webster
Re: Specifying active Theme in plugin_customization.ini [message #333776 is a reply to message #333735] Mon, 05 January 2009 08:55 Go to previous message
Searching bugzilla revealed two bug entries related to the topic:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214352
[Themes] org.eclipse.ui/CURRENT_THEME_ID unconditionally overruled in
WorkbenchThemeManager
https://bugs.eclipse.org/bugs/show_bug.cgi?id=215839
WorkbenchThemeManager is overriding theme set in plugin_customization.ini
The latter seems to be fixed in eclipse 3.4 - we'll have to check this asap.
Previous Topic:IMementoAware ? saving selection of CommonNavigator for latter restoring
Next Topic:No solution found because the problem in /tmp/p2Encoding13004.opb is unsatisfiable.
Current Time: Thu Jul 17 09:30:31 EDT 2025
Powered by FUDForum. Page generated in 0.09166 seconds
