Home » Eclipse Projects » Eclipse Platform » "Build before launch" ant task switch
"Build before launch" ant task switch [message #333606] Thu, 18 December 2008 06:15 Go to next message
Strange problem with an ant task which is supposed to compile and build.
However, the "Launchin <project name> (x%)" message keep showing on the
right hand corner every time it is run, which seems like Eclipse is
cleaning the build folder and starts to compile the whole project, which
is not necessary cuz the ant task itself is supposed to do it instead of
Eclipse. And it turns out it is, when the red stop button is clicked the
build folder is found to be empty or have some classes compiled.
Checked the following:
1. "Build before launch" is not checked.
2. Build automatically is turned off.
It happens on Ganymede. The same build.xml, and same set of project on
another machine with Europa is fine. On Europa the task will start
immediately (without Eclipse doing the build).
Any thoughts/ideas will be greatly appreciated. Thanks in advance.
Re: "Build before launch" ant task switch [message #333877 is a reply to message #333606] Mon, 12 January 2009 05:29 Go to previous message
Thu, 18 Dec 2008 11:15:51 +0000 (UTC), /coma/:
> ... seems like Eclipse is
> cleaning the build folder and starts to compile the whole project...
I'm experiencing this ever since I've switched to using Ganymede,
too. Are you aware of any relevant bug reports filled?
Stanimir
Previous Topic:is ganymedge stable for use?
Next Topic:CVS metadata
Current Time: Wed Nov 05 08:20:58 EST 2025
Powered by FUDForum. Page generated in 0.03068 seconds
