Home » Eclipse Projects » Eclipse Platform » Enablement of contributed actions
Enablement of contributed actions [message #333602] Thu, 18 December 2008 05:17 Go to next message
My plugin will contribute actions to toolbars and popup menus. These
actions should only be enabled if there is a file called domain-model.uml
in the project that is selected or indirectly selected trough the selected
resource.
Is it possible to achieve this somehow trough the extension point
mechanism?
Thanks for any answers.
Re: Enablement of contributed actions [message #333622 is a reply to message #333602] Thu, 18 December 2008 10:34 Go to previous message
If it has to be in a known location, you can check for it relatively
easily. If it can be anywhere in the project, that's too costly to
search for during a visible or enabled check in a menu.
You can do this kinds of checking with actions or action extensions
(like actionSets) and IActionFilter, or with commands/handlers and
enabledWhen (core expressions).
PW
Paul Webster
Previous Topic:Mark stack frame in Debugger
Next Topic:Inconsistent behaviour in TextEditor
Current Time: Fri Sep 05 12:28:13 EDT 2025
Powered by FUDForum. Page generated in 0.02605 seconds
