Home » Eclipse Projects » Eclipse Platform » Position of an action that is added to eclipse via popUpMenus extension point
Position of an action that is added to eclipse via popUpMenus extension point [message #333575] Wed, 17 December 2008 10:41 Go to next message
I have a little question. I'm adding actions to Eclipse that are
accessible via context menu. For that I use the org.eclipse.ui.popupMenus
extension point.
I add my actions into a submenu to the additions path of the context menu.
There are other actions as well from other plugins. Now I want my actions
to appear at the very bottom of that menu. Right now they are at the very
top. How can I accomplish that?
Re: Position of an action that is added to eclipse via popUpMenus extension point [message #333577 is a reply to message #333575] Wed, 17 December 2008 14:14 Go to previous message
You can't really, unless you target a group that's *not* additions.
Everything that goes into additions happens in a non-deterministic order
(simply when that particular extension is processed).
But if you had your own group to contribute to, that would provide more
control.
PW
Paul Webster
Previous Topic:Examples?
Next Topic:Re: Retrieve feature info
Current Time: Mon Nov 17 23:25:56 EST 2025
Powered by FUDForum. Page generated in 0.03286 seconds
