| I get "NLS unused message" at Eclipse 3.3.2 startup [message #333522] |
Tue, 16 December 2008 09:15  |
Hello
i use Eclipse 3.3.2
Every time i start Eclipse, i have the following message in error log tab:
eclipse.buildId=I20070625-1500
java.version=1.5.0_12
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:30.164
!MESSAGE NLS unused message: ShowView_selectViewHelp in:
org.eclipse.ui.internal.messages
!MESSAGE NLS unused message: ShowView_noDesc in:
!MESSAGE NLS unused message: PerspectivesPreference_perspectiveopen_title
in: org.eclipse.ui.internal.messages
PerspectivesPreference_perspectiveopen_message in:
!MESSAGE NLS unused message: FilteredTree_AccessibleListenerFiltered in:
!MESSAGE NLS unused message: ContentTypes_fileAssociationsEditLabel in:
!MESSAGE NLS unused message: ContentTypes_addDialog_title in:
!MESSAGE NLS unused message: ContentTypes_addDialog_messageHeader in:
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:30.179
!MESSAGE NLS unused message: ContentTypes_addDialog_message in:
!MESSAGE NLS unused message: ContentTypes_addDialog_label in:
!MESSAGE NLS unused message: ContentTypes_editDialog_title in:
!MESSAGE NLS unused message: ContentTypes_editDialog_messageHeader in:
!MESSAGE NLS unused message: ContentTypes_editDialog_message in:
!MESSAGE NLS unused message: ContentTypes_editDialog_label in:
!MESSAGE NLS unused message: WorkbenchStatusDialog_StatusLabel in:
!MESSAGE NLS unused message: WorkbenchStatusDialog_NotAvailable in:
!MESSAGE NLS unused message: WorkbenchStatusDialog_TimestampNotAvailable
!MESSAGE NLS unused message: WorkbenchStatusDialog_ExplanationLabel in:
!MESSAGE NLS unused message: WorkbenchStatusDialog_ActionLabel in:
!MESSAGE NLS unused message: WorkbenchStatusDialog_CopyThisReport in:
!MESSAGE NLS unused message: WorkbenchStatusDialog_Support in:
!MESSAGE NLS unused message: WorkbenchStatusDialog_StatusWithChildren in:
!MESSAGE NLS unused message: WorkbenchStatusDialog_NoMessageAvailable in:
!MESSAGE NLS unused message: WorkbenchStatusDialog_SeeDetails in:
WorkbenchStatusDialog_MultipleProblemsHaveOccured in:
!MESSAGE NLS unused message: StackTraceSupportArea_CausedBy in:
!MESSAGE NLS unused message: StackTraceSupportArea_NoStackTrace in:
!MESSAGE NLS unused message: StackTraceSupportArea_Title in:
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:30.195
WorkingSetConfigurationBlock_WorkingSetText_name in:
WorkingSetConfigurationBlock_SelectWorkingSet_button in:
WorkingSetPropertyPage_ReadOnlyWorkingSet_description in:
WorkingSetPropertyPage_ReadOnlyWorkingSet_title in:
!MESSAGE NLS unused message: WorkingSetGroup_EnableWorkingSet_button in:
!MESSAGE NLS unused message: WorkingSetGroup_WorkingSetSelection_message
!MESSAGE NLS unused message: WorkingSetGroup_WorkingSets_group in:
!MESSAGE NLS unused message: ViewsPreference_useColoredLabels in:
!MESSAGE NLS unused message: WorkbenchStatusDialog_ProblemOccurred in:
!MESSAGE NLS unused message: WorkbenchStatusDialog_ProblemOccurredInJob
!MESSAGE NLS unused message: WorkbenchPreference_allowInplaceEditingButton
!MESSAGE NLS unused message: FilteredPreferenceDialog_Resize in:
!MESSAGE NLS unused message: AboutPluginsDialog_columns in:
!MESSAGE NLS unused message: AboutFeaturesDialog_columns in:
!MESSAGE NLS unused message: ViewMenu in: org.eclipse.ui.internal.messages
!MESSAGE NLS unused message: Workbench_NeedsClose_Title in:
!MESSAGE NLS unused message: Workbench_NeedsClose_Message in:
!MESSAGE NLS unused message: AbstractWorkingSetManager_updatersActivating
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:30.460
CreateLinkedResourceGroup_targetSelectionTitle in:
org.eclipse.ui.internal.ide.messages
!MESSAGE NLS unused message: CleanDialog_globalBuildButton in:
!MESSAGE NLS unused message: CleanDialog_buildSelectedProjectsButton in:
!MESSAGE NLS unused message: UnsupportedVM_message in:
!MESSAGE NLS unused message: IDEWorkbenchActivityHelper_jobName in:
!MESSAGE NLS unused message: ProjectLocationSelectionDialog_locationIsSelf
in: org.eclipse.ui.internal.ide.messages
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:30.476
!MESSAGE NLS unused message: OpenResourceDialog_openButton_text in:
!MESSAGE NLS unused message: OpenResourceDialog_openWithMenu_label in:
!MESSAGE NLS unused message: OpenResourceDialog_openWithButton_toolTip in:
!MESSAGE NLS unused message: CleanDialog_cleanSelectedTaskName in:
!MESSAGE NLS unused message: CleanDialog_cleanAllTaskName in:
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:30.523
!MESSAGE NLS unused message: JobInfo_Cancel_Requested in:
org.eclipse.ui.internal.progress.messages
!MESSAGE NLS unused message: InternalError in:
!ENTRY org.eclipse.ui.workbench 2 0 2008-12-16 15:10:37.179
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-12-16 15:10:37.179
!MESSAGE Conflict for
'AUTOGEN:::com.omondo.uml.std.ui.check.diagram/com.omondo.um l.std.ui.actions.check.diagram':
HandlerActivation(commandId=AUTOGEN:::com.omondo.uml.std.ui. check.diagram/com.omondo.uml.std.ui.actions.check.diagram,
handler=ActionDelegateHandlerProxy(null,com.omondo.uml.std.e xternal.UMLCheckDiagramAction),
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@1382926),sourcePriority=16384)
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:46.273
!MESSAGE NLS unused message: RegistryView_found_problems in:
org.eclipse.pde.internal.runtime.pderuntimeresources
!MESSAGE NLS unused message: RegistryBrowser_plugins in:
!MESSAGE NLS unused message: RegistryView_startAction_label in:
!MESSAGE NLS unused message: RegistryView_stopAction_label in:
!MESSAGE NLS unused message: RegistryView_enableAction_label in:
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:46.351
!MESSAGE NLS unused message: RegistryView_disableAction_label in:
!MESSAGE NLS unused message: RegistryView_no_unresolved_constraints in:
!MESSAGE NLS unused message: SpyDialog_title in:
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:46.367
!MESSAGE NLS unused message: SpyDialog_close in:
!MESSAGE NLS unused message: SpyDialog_activeSelection_title in:
!MESSAGE NLS unused message: SpyFormToolkit_saveImageAs_title in:
!MESSAGE NLS unused message: SpyFormToolkit_copyQualifiedName in:
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:46.429
!MESSAGE NLS unused message: RegistryBrowser_copy_label in:
!MESSAGE NLS unused message: SpyIDEUtil_noSourceFound_message in:
!MESSAGE NLS unused message: SpyDialog_activePageBook_title in:
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:46.554
!MESSAGE NLS unused message: FileLabelProvider_line_number in:
org.eclipse.search.internal.ui.SearchMessages
!MESSAGE NLS unused message: FileSearchPage_open_file_failed in:
!MESSAGE NLS unused message: FileSearchPage_limited_format_files in:
!MESSAGE NLS unused message: FileSearchPage_limited_format_matches in:
!MESSAGE NLS unused message: FileSearchPage_open_file_dialog_title in:
!MESSAGE NLS unused message: ReplaceAction_title_all in:
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:46.570
!MESSAGE NLS unused message: ReplaceAction_description_operation in:
!MESSAGE NLS unused message: ReplaceAction_title_selected in:
!MESSAGE NLS unused message: ReplaceRefactoring_refactoring_name in:
!MESSAGE NLS unused message: ReplaceRefactoring_error_no_matches in:
!MESSAGE NLS unused message: ReplaceRefactoring_error_no_changes in:
ReplaceRefactoring_group_label_change_for_file in:
!MESSAGE NLS unused message: ReplaceRefactoring_group_label_match_replace
in: org.eclipse.search.internal.ui.SearchMessages
!MESSAGE NLS unused message: ReplaceRefactoring_result_update_name in:
!MESSAGE NLS unused message: ReplaceRefactoring_composite_change_name in:
!MESSAGE NLS unused message: ReplaceRefactoring_error_access_file in:
ReplaceRefactoring_error_illegal_search_string in:
!MESSAGE NLS unused message: ReplaceRefactoring_error_no_replace_string
ReplaceRefactoring_error_accessing_file_buffer in:
ReplaceRefactoring_error_match_content_changed in:
ReplaceRefactoring_error_replacement_expression in:
!MESSAGE NLS unused message: ReplaceConfigurationPage_replace_label in:
!MESSAGE NLS unused message: ReplaceConfigurationPage_with_label in:
!MESSAGE NLS unused message: ReplaceConfigurationPage_isRegex_label in:
ReplaceConfigurationPage_description_many_in_many in:
ReplaceConfigurationPage_description_one_in_one in:
ReplaceConfigurationPage_description_many_in_one in:
!MESSAGE NLS unused message: PatternConstructor_error_escape_sequence in:
!MESSAGE NLS unused message: PatternConstructor_error_hex_escape_sequence
!MESSAGE NLS unused message: PatternConstructor_error_line_delim_position
PatternConstructor_error_unicode_escape_sequence in:
!ENTRY org.eclipse.osgi 2 1 2008-12-16 15:10:46.585
!MESSAGE NLS unused message: SearchView_empty_search_label in:
org.eclipse.search2.internal.ui.SearchMessages
!MESSAGE NLS unused message: RetrieverAction_dialog_title in:
Anyone can tell me how can i resolve this problem?
Sincerly
| Re: I get "NLS unused message" at Eclipse 3.3.2 startup [message #333551 is a reply to message #333522] |
Wed, 17 December 2008 03:20  |
Originally posted by: sf.tragwerk-software.de
please have a look at bugs
https://bugs.eclipse.org/bugs/show_bug.cgi?id=257427
https://bugs.eclipse.org/bugs/show_bug.cgi?id=257332
https://bugs.eclipse.org/bugs/show_bug.cgi?id=257439
please post your warnings there. if you updated babel packages don't
forget to tell the babel version.
thanks.
sebastian
Laurent Tourreau schrieb:
> Hello i use Eclipse 3.3.2
> PerspectivesPreference_perspectiveopen_title in:
> WorkbenchPreference_allowInplaceEditingButton in:
> AbstractWorkingSetManager_updatersActivating in:
> ProjectLocationSelectionDialog_locationIsSelf in:
> ReplaceRefactoring_group_label_match_replace in:
> PatternConstructor_error_hex_escape_sequence in:
> PatternConstructor_error_line_delim_position in:
> Sincerly
FUDForum. Page generated in 0.03985 seconds
