Home » Eclipse Projects » Eclipse Platform » How to enable debug in plugin
How to enable debug in plugin [message #333494] Mon, 15 December 2008 13:28 Go to next message
The plugin that I am working on has Plugin.class that has the
setDebugging(boolean). How can I set it to true when I run Eclipse
Application to test my plugin.
cheers,
//mike
Re: How to enable debug in plugin [message #333502 is a reply to message #333494] Mon, 15 December 2008 14:48 Go to previous message
Mikael Petterson wrote:
You could simply check
org.eclipse.core.runtime.Platform.inDevelopmentMode() which is active
when you are in development mode.
The other option is to set up your plugin similar to
org.eclipse.ui.internal.misc.Policy ... and use the debug options
pattern used by the eclipse SDK. a .options file that describes your
properties is placed in the base of your plugin and that is used to turn
tracing on or off (and can even be used from the launch config).
PW
Paul Webster
Previous Topic:Edit menu options do not get enabled for all views
Next Topic:get File or class Name from IDocumet
Current Time: Mon Sep 01 00:30:52 EDT 2025
Powered by FUDForum. Page generated in 0.02734 seconds
