Home » Eclipse Projects » Eclipse Platform » Changing model for a TableViewer in a View
Changing model for a TableViewer in a View [message #333490] Mon, 15 December 2008 10:52 Go to next message
Originally posted by: sean.mitchwood.com
Hi All..
I'm working on an RCP app that has a view which lists items in a
TableViewer.
The view is backed by a model which is provided as a service by OSGi
declarative services, and so typically it may or may not available.
My problem is that when the model turns up in my ServiceTracker, and I
call setInput(model) and then refresh() on the TableViewer, my View does
not refresh itself.
In the ContentProvider I can see that inputChanged() is being called,
but not getElements().
I'm not sure if I've approached this the right way, but it's certainly
not working as I expected.
Anyone have any insight on this problem?
Sean
Re: Changing model for a TableViewer in a View [message #333507 is a reply to message #333490] Tue, 16 December 2008 06:15 Go to previous messageGo to next message
did you call the setInput(model) and refresh on the SWT Event thread
using Display.asyncExec? Maybe this could solve the problem...
On Mon, 15 Dec 2008 10:52:32 -0500, Sean Mitchell <sean@mitchwood.com>
wrote:
>Hi All..
>TableViewer.
>not refresh itself.
>Cheers,
>Sean
Re: Changing model for a TableViewer in a View [message #333524 is a reply to message #333507] Tue, 16 December 2008 09:20 Go to previous messageGo to next message
Thanks, I did, still no luck, although it did get me past the thread
access exception I didn't realise I was having. I hate how all these
exceptions are quietly hidden away... is there any way in the PDE to
make exceptions a little more noticeable?
Sean
Re: Changing model for a TableViewer in a View [message #333526 is a reply to message #333524] Tue, 16 December 2008 09:31 Go to previous messageGo to next message
Yes run with -consoleLog and you'll see them all.
Tom
> Cheers,
> Sean
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Changing model for a TableViewer in a View [message #333535 is a reply to message #333526] Tue, 16 December 2008 22:37 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
Store the input object in Vector or ArrayList. Then set the vector/arraylist as input. Check for the instanceof of the input element in getElements method as in the following code. Make sure that the methods in label provider also checks for instanceof input element.
public Object[] getElements(Object inputElement) {
   ArrayList<Object> objList = new ArrayList<Object>();
   if (inputElement instanceof Vector) {
      objList.addAll((Vector) inputElement);
   return objList.toArray();
~Prasanna
Re: Changing model for a TableViewer in a View [message #333537 is a reply to message #333526] Tue, 16 December 2008 22:39 Go to previous messageGo to next message
Make sure that the methods in label provider also checks for instanceof of the input element.
~Prasanna
Re: Changing model for a TableViewer in a View [message #333539 is a reply to message #333526] Tue, 16 December 2008 22:40 Go to previous messageGo to next message
~Prasanna
Re: Changing model for a TableViewer in a View [message #333540 is a reply to message #333524] Tue, 16 December 2008 22:41 Go to previous messageGo to next message
Make sure that the methods in label provider class also checks for instanceof of the input element before retrieveing the data.
~Prasanna
Re: Changing model for a TableViewer in a View [message #333546 is a reply to message #333540] Wed, 17 December 2008 00:31 Go to previous messageGo to next message
I am sorry for the repeated replies. I noticed that the server threw exception on replies, hence I tried posting the messages repeatedly.
Thanks for understanding.
~Prasanna
Re: Changing model for a TableViewer in a View [message #333582 is a reply to message #333546] Wed, 17 December 2008 16:31 Go to previous messageGo to next message
Yeah man, no problem.
Thanks to all of you on this thread for your help... between your
various bits of advice I have it working now.
Arawak
Re: Changing model for a TableViewer in a View [message #333640 is a reply to message #333490] Fri, 19 December 2008 07:15 Go to previous message
Could you please provide some sample code on how you invoke the
methods in question?
wrote:
>Hi All..
>TableViewer.
>not refresh itself.
>Cheers,
>Sean
Previous Topic:How can I change the location where the project files are stored?
Next Topic:debugging plugins at runtime?
Current Time: Fri Nov 07 20:25:30 EST 2025
Powered by FUDForum. Page generated in 0.04065 seconds
