Home » Eclipse Projects » Eclipse Platform » Edit menu options do not get enabled for all views
Edit menu options do not get enabled for all views [message #333487] Mon, 15 December 2008 07:12 Go to next message
I have three views in my plug-in.
I want to make available Edit menu options (cut / copy / paste) to the
user based on current selection.
I have written a method called initializeEditOptions() in a class that is
not a view nor an editor. This method gets called only when each of the
three views of my perspective is up.
It has the code to initialize copy / cut / paste Action variables like :
public void initializeEditOptions() {
// create actions for edit menu options
copyEAction = new org.eclipse.jface.action.Action() {
public void run() {
//copy stuff
super.run();
// similarly for cut and paste
// code to create actionBars
final IActionBars[] actionBars = new IActionBars[1];
Display display = Display.getDefault();
display.syncExec(new Runnable() {
public void run() {
IWorkbenchPartSite site =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().getActivePart().getSite();
if(site instanceof IViewSite)
actionBars[0] = (IViewSite)site).getActionBars();
else if (site instanceof IEditorSite)
actionBars[0] = ((IEditorSite)site).getActionBars();
actionBars[0].setGlobalActionHandler(ActionFactory.COPY.getI d(),
copyEAction);
copyEAction.setEnabled(false);
// similarly for copy and paste
There is a different method called updateMenus() in which I set enable
property of cut / copy actions to true based on some conditions and
selections.
The edit menu options get enabled only when a certain view (among three)
becomes the active part and not when the other views are active.
What could be the problem and how do I solve this?
Re: Edit menu options do not get enabled for all views [message #333501 is a reply to message #333487] Mon, 15 December 2008 14:41 Go to previous message
> is not a view nor an editor. This method gets called only when each of
> the three views of my perspective is up.
> selections.
How many times is that method called? Basically, you are registering
your actions for 1 part, ....getActivePage().getActivePart().getSite()
If you really want to use 3 common handlers for the different views,
activate the handler for the command when the view is created:
initialize(IViewPart part) {
IHandlerService hs = (IHandlerService)
part.getSite().getService(IHandlerService.class);
hs.activateHandler("org.eclipse.ui.edit.copy", commonCopyHandler);
hs.activateHandler("org.eclipse.ui.edit.cut", commonCutHandler);
// etc
IHandlers support setEnabled(true/false) and as long as they fire the
change event (usually subclasses off of AbstractHandler) they will
update the commands correctly.
PW
Paul Webster
Previous Topic:rcp and plugin startup code
Next Topic:How to enable debug in plugin
Current Time: Sat Nov 29 16:30:11 EST 2025
Powered by FUDForum. Page generated in 0.04618 seconds
