Home » Eclipse Projects » Eclipse Platform » Run/Debug configuration persistent location
Run/Debug configuration persistent location [message #333454] Thu, 11 December 2008 14:26 Go to next message
I would like to share run/debug configurations both between users and
between workspaces. Ideally I'd like to save them in our repository but I
haven't figured out where they are kept. If there is already a mechanism
for exporting/importing them that would be great but if not I'd appreciate
knowing where I can find them.
Scott
Re: Run/Debug configuration persistent location [message #333457 is a reply to message #333454] Thu, 11 December 2008 14:39 Go to previous messageGo to next message
> I haven't figured out where they are kept. If there is already a
> mechanism for exporting/importing them that would be great but if not
> I'd appreciate knowing where I can find them.
> Scott
They are in your workspace directory under
/.metadata/.plugins/org.eclipse.debug.core/.launches
File > Export > Run/Debug > LaunchConfigurations.
jjb
Re: Run/Debug configuration persistent location [message #333459 is a reply to message #333457] Thu, 11 December 2008 16:58 Go to previous message
Originally posted by: wegener.cboenospam.com
"John J Barton" <johnjbarton@johnjbarton.com> wrote in message
news:ghrq59$ush$2@build.eclipse.org...
> > Thanks,
> > Scott
The easier way is to use the Common tab on the Run Configurations dialog.
If you select Shared file, you can place the launch config in your project.
It can then be checked in with the rest of your source.
Checking out the project will automatically recognize the launch
configuration and add it to the the dialog.
> jjb
Previous Topic:How to learn eclipse source code
Next Topic:MacOS X: Cannot run or debug Eclipse Application
Current Time: Fri Jul 18 21:48:32 EDT 2025
Powered by FUDForum. Page generated in 0.04244 seconds
