Home » Eclipse Projects » Eclipse Platform » [Databinding} Mess with tables/ Validation in structured Beans
[Databinding} Mess with tables/ Validation in structured Beans [message #333400] Tue, 09 December 2008 11:27 Go to next message
This is parially a cross post to something I asked on the SWT group.
Guess I have an editor that edits a person object. a person has many
adresses so the editor shows them in a table. but withmy current
solution the fields in the table can only be validated when the user
edits cells (via EditingSupport) bindings are dynamically created. But
in my scenario I cant create a valid new record. So if the user doesnt
edit it he will never see any validating message. Are there any ideas
out there to solve that ?
Re: [Databinding} Mess with tables/ Validation in structured Beans [message #333402 is a reply to message #333400] Tue, 09 December 2008 12:05 Go to previous messageGo to next message
Any cross-observable or compound constraint validators should be
enforced using a ValidationStatusProvider. You can extend
ValidationStatusProvider and manually monitor your address collection
for validation errors. Or, you could extend MultiValidator and have it
monitor the relevant observables to check for errors. If you are using
ObservableMapLabelProvider then I would suggest observing the values()
for the IObservableMap used by the relevant table column.
As an example:
TableViewer addressViewer = ...
ObservableListContentProvider cp = new ObservableListContentProvider();
final IObservableMap[] maps = BeansObservables.observeMaps(
cp.getKnownElements,
Address.class,
new String[] {"street", "street2", "city", "province", "code" } );
addressViewer.setLabelProvider(new ObservableMapLabelProvider(maps));
MultiValidator addressValidator = new MultiValidator(realm) {
protected IStatus validate() {
Set addresses = maps[0].keySet();
IStatus status = ValidationStatus.ok();
for (Iterator it = addresses.iterator(); it.hasNext(); ) {
Address address = (Address) it.next();
// validate address, update status variable if more severe
// than current value
return status;
Hope this helps,
Matthew Hall
Re: [Databinding} Mess with tables/ Validation in structured Beans [message #333403 is a reply to message #333402] Tue, 09 December 2008 12:07 Go to previous messageGo to next message
> Address.class,
> return status;
Forgot to say, you need to add the MultiValidator to the DataBindingContext:
dbc.addValidationStatusProvider(addressValidator);
Matthew
Re: [Databinding} Mess with tables/ Validation in structured Beans [message #333419 is a reply to message #333403] Wed, 10 December 2008 09:25 Go to previous messageGo to next message
Thanks Matthew,
thats exactly what I was looking for !
Thomas
>> Address.class,
>> return status;
> DataBindingContext:
> Matthew
Re: [Databinding} Mess with tables/ Validation in structured Beans [message #333443 is a reply to message #333419] Thu, 11 December 2008 10:06 Go to previous message
Hi Thomas,
Would you be able to write a new snippet for this and contribute it through
Bugzilla?
Boris
"Thomas" <thomas.kratz@eiswind.de> wrote in message
news:ghojga$ta5$1@build.eclipse.org...
> Thanks Matthew,
> Thomas
>>> Address.class,
>>> return status;
>> DataBindingContext:
>> Matthew
Previous Topic:[jface] ComboBoxCellEditor activation with EditingSupport API
Next Topic:Job.schedule( ) performance problem
Current Time: Sat Nov 08 18:32:18 EST 2025
Powered by FUDForum. Page generated in 0.04346 seconds
