| Actions and command handlers [message #333384] |
Mon, 08 December 2008 10:18  |
I encoutered a problem while working with actions and commands/handlers
associated with it in Eclipse 3.4.
In my application I have a TreeViewer with a context menu. Depending on
the selected object in the tree, I have different "new" actions to
create a new element of the given type.
I tried now to add the key accelerator "CTRL+N" to all these new actions
(at any time, only one action can be associated with this key binding),
by defining a command with a keybinding:
<extension
point="org.eclipse.ui.commands">
<command
categoryId="myCategory"
description="Create new element"
id="first.test.newCommand"
name="Create element">
</command>
</extension>
<extension
point="org.eclipse.ui.bindings">
<key
commandId="first.test.newCommand"
contextId="contextOfMyView"
schemeId="org.eclipse.ui.defaultAcceleratorConfiguration"
sequence="CTRL+N">
</key>
</extension>
and the following handlers:
<extension
point="org.eclipse.ui.handlers">
<handler
class="NewElementAHandler"
commandId="first.test.newCommand">
<activeWhen>
<iterate>
<instanceof value="ElementA">
</instanceof>
</iterate>
</activeWhen>
</handler>
<handler
class="NewElementBHandler"
<activeWhen>
<iterate>
<instanceof value="ElementB">
</instanceof>
</iterate>
</activeWhen>
</handler>
</extension>
The actions in the context menu are objectContributions:
<extension
point="org.eclipse.ui.popupMenus">
<objectContribution
objectClass="ElementA"
id="ElementA_Actions">
<action
enablesFor="1"
label="New Element A"
class="NewElementAAction"
menubarPath="navigator.new"
definitionId="first.test.newCommand"
</action>
</objectContribution>
<objectContribution
objectClass="ElementB"
id="ElementB_Actions">
<action
enablesFor="1"
label="New Element B"
class="NewElementBAction"
</action>
</extension>
So far, everything works fine. If an element of type ElementA is
selected, the accelerator key invokes NewElementAHandler and the same
for elements of type ElementB. But in the logfile I find many log
entries that inform about conflicting handlers.
It seems to me, that eclipse itself generates Handlers to wrap actions
with a given definitionId. And these generated handlers seem to cause
these conflicts.
Is there any way to solve this problem?
Dirk
| Re: Actions and command handlers [message #333388 is a reply to message #333384] |
Mon, 08 December 2008 12:47   |
Dirk Wenke wrote:
> <extension
> <command
> </command>
> </extension>
> <extension
> <key
> sequence="CTRL+N">
> </key>
> </extension>
> <extension
> <handler
> <activeWhen>
> <iterate>
> </instanceof>
> </iterate>
> </activeWhen>
> </handler>
> <handler
> <activeWhen>
> <iterate>
> </instanceof>
> </iterate>
> </activeWhen>
> </handler>
> </extension>
> <extension
> <objectContribution
> <action
> enablesFor="1"
> </action>
> <objectContribution
> <action
> enablesFor="1"
> </action>
> </extension>
> these conflicts.
Don't mix commands and actions. If you have already created commands
and handlers, simply use org.eclipse.ui.menus to place your command in
the appropriate popup menu.
Then executing the menu item will execute the command, which will point
to the appropriate handler.
PW
Paul Webster
| Re: Actions and command handlers [message #333461 is a reply to message #333388] |
Fri, 12 December 2008 03:40   |
Thanks Paul,
that did the trick! But there is now one problem left.
Using the org.eclipse.ui.menus extension point I succeded to contribute
elements to the popupmenu which are directly linked to my commands.
But I have problems contributing to submenus of the contextmenu.
<extension
point="org.eclipse.ui.menus">
<menuContribution
locationURI="popup:my.view?after=startGroup">
<menu
id="refactor.submenu"
label="Refactor">
</menu>
</menuContribution>
</extension>
If I define popup elements directly as command subelements of the menu
definition, they are shown in the submenu.
But I do not succeed to contribute from other plugins into that submenu.
Maybe I am using the wrong locationURI?
I tried
locationURI="popup:my.view?after=refactor.submenu"
I even tried the definition of a separator in the submenu and then used
the identifier of the separator in the locationURI
locationURI="popup:my.view?after=refactor.mySeparator"
Any ideas?
Dirk
> Dirk Wenke wrote:
>> commands/handlers associated with it in Eclipse 3.4.
>> on the selected object in the tree, I have different "new" actions to
>> actions (at any time, only one action can be associated with this key
>> binding), by defining a command with a keybinding:
>> <extension
>> <command
>> </command>
>> </extension>
>> <extension
>> <key
>> sequence="CTRL+N">
>> </key>
>> </extension>
>> <extension
>> <handler
>> <activeWhen>
>> <iterate>
>> </instanceof>
>> </iterate>
>> </activeWhen>
>> </handler>
>> <handler
>> <activeWhen>
>> <iterate>
>> </instanceof>
>> </iterate>
>> </activeWhen>
>> </handler>
>> </extension>
>> <extension
>> <objectContribution
>> <action
>> enablesFor="1"
>> </action>
>> <objectContribution
>> <action
>> enablesFor="1"
>> </action>
>> </extension>
>> these conflicts.
> PW
FUDForum. Page generated in 0.03161 seconds
