Home » Eclipse Projects » Eclipse Platform » Where is PDE repo
Where is PDE repo [message #333383] Mon, 08 December 2008 08:51 Go to next message
There is an info that PDE repo has been moved to
dev.eclipse.org:/cvsroot/eclipse/pde
but no such a repo exists.
where are PDE sources ?
bartek michalik
Re: Where is PDE repo [message #333387 is a reply to message #333383] Mon, 08 December 2008 12:43 Go to previous messageGo to next message
AFAIK you would still use dev.eclipse.org:/cvsroot/eclipse ... just
expand pde and then check out the plugins
PW
Paul Webster
Re: Where is PDE repo [message #333429 is a reply to message #333387] Wed, 10 December 2008 17:19 Go to previous message
> PW
Paul is correct, the repository has not moved, just the project location
within the repository.
Previous Topic:Question regarding Eclipse Jobs
Next Topic:Cannot run program "make": Unknown reason
Current Time: Fri Nov 14 19:23:05 EST 2025
Powered by FUDForum. Page generated in 0.04191 seconds
