Home » Eclipse Projects » Eclipse Platform » Doubleclick doesn't set a breakpoint
Doubleclick doesn't set a breakpoint [message #333373] Sat, 06 December 2008 06:31 Go to next message
currently Eclipse (I use version 3.2.2) doesn't set a breakpoint for
debugging when I doubleclick at the left border of the code editor within a
method. Some weeks ago it still worked. I have no idea, what may have
happened and changed, that on doubleclick Eclipse doesn't set the breakpoint
anymore. Fortunately I can still set the breakpoint by the context function
Toggle Breakpoint.
What may be the reason, that Eclipse doesn't set a breakpoint after a
doubleclick?
How to resolve the problem?
Thomas Wiedmann
Re: Doubleclick doesn't set a breakpoint [message #333374 is a reply to message #333373] Sun, 07 December 2008 02:48 Go to previous messageGo to next message
I'd suggest using a more recent version personally...
> within a method.
Does Ctrl+Shift+B work? Personally, I use that instead of clicking on
the border.
Remy
Re: Doubleclick doesn't set a breakpoint [message #333376 is a reply to message #333373] Sun, 07 December 2008 22:04 Go to previous messageGo to next message
> Hello,
> within a method. Some weeks ago it still worked. I have no idea, what
> may have happened and changed
Sometimes Eclipse seems to get confused (or at least I get confused)
when the linkage between binary and source gets messed up - for
instance, if the same source file exists in two different projects, or
if a type is coming from a .jar file rather than from the compiled
output of the project containing the source file you're looking at.
Is it possible that you added a jar file, containing the type in
question, to the classpath?
Re: Doubleclick doesn't set a breakpoint [message #333382 is a reply to message #333373] Mon, 08 December 2008 08:48 Go to previous message
On 12/6/2008 6:31 AM, Thomas Wiedmann wrote:
> Hello,
> may have happened and changed, that on doubleclick Eclipse doesn't set
> the breakpoint anymore. Fortunately I can still set the breakpoint by
> the context function Toggle Breakpoint.
> doubleclick?
First I'd recommend upgrading to the latest version. You might be
running into this bug, which has been fixed:
https://bugs.eclipse.org/239317 (you'd see the NPE in your Error Log, if
that is the problem).
Hope this helps,
Eric
Previous Topic:Catch every mouse click
Next Topic:Console View - default console displayed setting
Current Time: Sun Oct 19 18:10:34 EDT 2025
Powered by FUDForum. Page generated in 0.04484 seconds
