Home » Eclipse Projects » Eclipse Platform » How do you save your custom colours?
How do you save your custom colours? [message #333368] Sat, 06 December 2008 02:41 Go to next message
Hi all,
I've noticed that when you're configuring syntax highlighting, the colour
selector has a number of spots where you can save frequently used colours.
This helps a lot to get a uniform colour scheme across all the
syntax-highlighting editors.
Unfortunately however it seems that any colours you set up are lost when you
restart Eclipse.
Is there any way to make Eclipse remember the custom colours you've set across
restarts? (Or can you edit the 'master list' somewhere?)
Adam.
Re: How do you save your custom colours? [message #333370 is a reply to message #333368] Sat, 06 December 2008 03:04 Go to previous messageGo to next message
> restart Eclipse.
The colour picker is something from the operating system. So I guess
that'd be an OS configuration, if it's even available.
Remy
Re: How do you save your custom colours? [message #333372 is a reply to message #333370] Sat, 06 December 2008 03:25 Go to previous messageGo to next message
>> set across
Ah ok - but doesn't Java provide an interface to this? Under one popular OS
the function to display the colour picker returns an array of user-specified
values, which it's up to the program to store and retrieve. If the Java
function does the same, then Eclipse should still save and retrieve those
values returned by the Java function.
I'm not familiar enough with Java to know which function displays this colour
picker window, so I can't check to see if this is the case.
Adam.
Re: How do you save your custom colours? [message #333375 is a reply to message #333372] Sun, 07 December 2008 14:16 Go to previous message
>>> set across
> Cheers,
> Adam.
This is most probably an OS issue. On OS X my list of custom colors is
global across ALL applications that use the native color picker.
Mike
Previous Topic:eclipse icon is not shown in title bar of the eclipse - linux
Next Topic:Activate plugin after installation without restart
Current Time: Sun Aug 31 19:56:58 EDT 2025
Powered by FUDForum. Page generated in 0.04590 seconds
