Home » Eclipse Projects » Eclipse Platform » [Databinding] EL support in JFace Databinding?
[Databinding] EL support in JFace Databinding? [message #333365] Fri, 05 December 2008 12:36 Go to next message
Coming from the Swing BeansBinding, I am used to being able to use EL
expression when doing binding, e.g.
"myProperty.itsProperty.anotherNestedChildProperty".
I cannot find the equivalent way of doing it in JFace databinding...it
seems you have to create the observables on the "final" object in this
hierarchy...there's no way to specify a nested hierarchy via an EL
expression.
I offer this functionality in my Java SwingBuilder library:
http://code.google.com/p/javabuilders/wiki/JavaBuilderDataBi nding
and would like to offer the same level of functionality in the Java
SWTBuilder I am currently working on.
Re: [Databinding] EL support in JFace Databinding? [message #333366 is a reply to message #333365] Fri, 05 December 2008 13:48 Go to previous message
You should check out the work in this enhancement request:
https://bugs.eclipse.org/195222
> expression.
> Thanks
Previous Topic:Multiple versions of library wrapper plugins
Next Topic:Loading my plugin when JDT loads
Current Time: Wed Jul 16 08:40:30 EDT 2025
Powered by FUDForum. Page generated in 0.26242 seconds
