Home » Eclipse Projects » Eclipse Platform » Running command in another plugin
Running command in another plugin [message #333195] Sat, 29 November 2008 18:27 Go to next message
I am currently using the CFEclipse plugin for its snippets functionality.
Included with the plugin is a command named
org.cfeclipse.cfml.editors.actions.InsertSnippet which inserts a snippet
based on some trigger text in the editor.
I want to build a simple plugin that has a single toolbar icon. When
clicked, I want it to call the command from the CFEclipse plugin. Can I do
that directly in my plugin.xml file or do I need to create an action that
calls their command?
Is this even possible?
Thanks so much,
Lee
Re: Running command in another plugin [message #333233 is a reply to message #333195] Mon, 01 December 2008 10:35 Go to previous message
You can use org.eclipse.ui.menus to call their command from plugin.xml
or IHandlerService to execute their command programmatically.
PW
Paul Webster
Previous Topic:preference extension point logic
Next Topic:[Databinding] ObservableMapLabelProvider + Tooltips
Current Time: Thu Oct 23 16:58:40 EDT 2025
Powered by FUDForum. Page generated in 0.04247 seconds
