Home » Eclipse Projects » Eclipse Platform » Treeviewer scrollbar misbehaves under windows?
Treeviewer scrollbar misbehaves under windows? [message #333193] Fri, 28 November 2008 11:55 Go to next message
Hi all
I would like to systematically to scroll a treeviewer, the value to scroll
is calculated outside and is passed onto the Treeviewer scrollbar
simplifying it is something like:
getViewer().getTree().getVerticalBar().setSelection(value)
The piece of code above under Linux scrolls my treeviewer to the wished
position, under winXP does nothing.
How could I workaround this problem?
Can I find an alternative solution to scroll my treeviewer (I do not know
the treeitem that will be shown)
many thanks for your help
Salvatore
Re: Treeviewer scrollbar misbehaves under windows? [message #333206 is a reply to message #333193] Mon, 01 December 2008 04:04 Go to previous messageGo to next message
Looks like an SWT-Issue. Redirecting to SWT-Newsgroup. Could you try
with an SWT only snippet [1]?
Tom
[1]http://www.eclipse.org/swt/snippets/
Salvatore schrieb:
> Hi all
> know the treeitem that will be shown)
> Salvatore
Re: Treeviewer scrollbar misbehaves under windows? [message #876368 is a reply to message #333193] Thu, 24 May 2012 09:17 Go to previous message
Hi Tom,
Even I am facing this issue. Is there any workaround now?
Previous Topic:Product Export: Unable to locate companion shared library
Next Topic:Exception occurred while saving project preferences
Current Time: Thu Nov 27 21:37:12 EST 2025
Powered by FUDForum. Page generated in 0.02690 seconds
