Home » Eclipse Projects » Eclipse Platform » problem exporting a plugin
problem exporting a plugin [message #333165] Thu, 27 November 2008 04:15 Go to next message
Originally posted by: luimarr1.upvnet.upv.es
Hi all,
I´m trying to export a plugin. It basically is the schema_editor gef
example with some modifications. The problem comes when I open the
export wizard for export it as a deployable plugin, the plugin does not
appear in the 'Available plugins and fragments' list.
Any idea of where am i mistaken??? (I already created the manifest and
so on)
Thanks in advances,
L.Marco
icon3.gif  Re: problem exporting a plugin [message #539527 is a reply to message #333165] Fri, 11 June 2010 04:13 Go to previous message
I had the same problem (My plug-in does not show in Deployable plug-ins and fragments list) and I found the solution. I realize your question is very old and you won't need the answer anymore but it may help others who work on old plug-ins.
Anyways, the reason (for me) was a lack of a build.properties file. I copied one from a freshly generated plug-in and it immediately showed in the 'Available Plug-ins and Fragments' list.
I also added the natures from the generated plug-in but that may not have been necessary.
Previous Topic:Key binding conflict with "Undefined Command"
Next Topic:Managing API-Leaks
Current Time: Sun Nov 09 23:23:43 EST 2025
Powered by FUDForum. Page generated in 0.03576 seconds
