Home » Eclipse Projects » Eclipse Platform » How to remove/replace the default key binding scheme
How to remove/replace the default key binding scheme [message #333038] Fri, 21 November 2008 05:14 Go to next message
I hope that someone can help me? I would like to use the "Keys" preference
window in my Eclipse RCP application.
However, I don't want the default key bindings to appear in the list of
keys. Is there a way for me to remove the default scheme and only have my
own scheme appear in the "Scheme:" dropdown? Or better yet, can I remove the
default scheme and have my own scheme appear as the default scheme?
Thanks in advance,
Anders Baumann
Re: How to remove/replace the default key binding scheme [message #333069 is a reply to message #333038] Mon, 24 November 2008 08:34 Go to previous messageGo to next message
Anders Baumann wrote:
You can set your scheme as the default using the
plugin_customization.ini file. See
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg24899.html
PW
Paul Webster
Re: How to remove/replace the default key binding scheme [message #333089 is a reply to message #333069] Tue, 25 November 2008 07:36 Go to previous messageGo to next message
Hi Paul.
Thanks for your answer. It works.
However, just like Klaus Paul we would also like to hide or disable the
Default and Emacs schemes at the preferences dialog, page keys. These
schemes are not useful in our RCP application and it seems strange the
Default scheme is not our scheme. Do you know if there is already a bug
report for this issue or should I file a bug report in Bugzilla?
Anders
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:ggeaus$b3b$1@build.eclipse.org...
>> preference
>> the
> You can set your scheme as the default using the plugin_customization.ini
> file. See
> PW
> Paul Webster
Re: How to remove/replace the default key binding scheme [message #333094 is a reply to message #333089] Tue, 25 November 2008 11:50 Go to previous messageGo to next message
I think it possible. I am struggling with the same issue but have put it
temporarily aside.
The reason I think it is possible is that NewKeysPreferencePage does it.
Press Shift-Ctrl-L twice and then unbind a command then press Shift-Ctrl-l
again, you will see that the command you unbound is not in the list.
So in theory it should be possible unbind any and or all the commands you
want.
Have a look at the code I posted, it is titled "Wwitch between Groups of
Key Bindings Dynamically", I reckon I am doing something silly wrong,
maybe later I will try and tackle this again.
Re: How to remove/replace the default key binding scheme [message #333098 is a reply to message #333089] Tue, 25 November 2008 15:23 Go to previous messageGo to next message
In an RCP app you would use
http://wiki.eclipse.org/Product_Customization probably with some kind of
XSL transform to yank out the default and emacs definitions that you
don't want to see. Use it to kind of mask them out.
PW
Paul Webster
Re: How to remove/replace the default key binding scheme [message #333133 is a reply to message #333098] Wed, 26 November 2008 13:11 Go to previous messageGo to next message
Ok, I have a solution at least for my needs.
The solution below will filter all commands that are not in the category
mycategory, you can define the criteria as you need.
To test do Ctrl+Shift+L you should see only the commands you have not
filtered.
IBindingService bindingService = (IBindingService) PlatformUI
getWorkbench().getAdapter(IBindingService.class);
BindingManager localChangeManager = new BindingManager(
new ContextManager(), new CommandManager());
try {
localChangeManager
.setActiveScheme(bindingService.getActiveScheme());
} catch (final NotDefinedException e) {
throw new Error(
"Error"); //$NON-NLS-1$
localChangeManager.setLocale(bindingService.getLocale());
localChangeManager.setPlatform(bindingService.getPlatform()) ;
localChangeManager.setBindings(bindingService.getBindings()) ;
Binding[] bindings = bindingService.getBindings();
for (Binding binding : bindings) {
if (binding.getTriggerSequence().format().equals("Ctrl+Shift+L ")) {
continue;
KeyBinding keyBinding = (KeyBinding) binding;
String contextId = binding.getContextId();
String schemeId = binding.getSchemeId();
KeySequence triggerSequence = keyBinding.getKeySequence();
ParameterizedCommand parameterizedCommand = binding
.getParameterizedCommand();
if (parameterizedCommand == null) {
continue;
Command command = parameterizedCommand.getCommand();
if (command == null) {
continue;
try {
if (!binding
getCommand()
getCategory()
getId()
equals(
"mycategory")) {
KeyBinding deleteBinding = new KeyBinding(triggerSequence,
null, schemeId, contextId, null, null, null,
Binding.USER);
localChangeManager.addBinding(deleteBinding);
} catch (NotDefinedException e) {
e.printStackTrace();
try {
bindingService.savePreferences(
localChangeManager.getActiveScheme(), localChangeManager
.getBindings());
} catch (IOException e) {
Re: How to remove/replace the default key binding scheme [message #333135 is a reply to message #333133] Wed, 26 November 2008 13:13 Go to previous messageGo to next message
does anyone know how I can get this to work without a dependency on
org.eclipse.ui.ide?
Re: How to remove/replace the default key binding scheme [message #333141 is a reply to message #333135] Wed, 26 November 2008 14:12 Go to previous message
Put this on top of your IApplication.start()
public Object start(IApplicationContext context) {
// set the default shortcuts
PlatformUI.getPreferenceStore().setDefault(IWorkbenchPrefere nceConstants.KEY_CONFIGURATION_ID,
"your.scheme"); //$NON-NLS-1$
// start your app
and you will have the default scheme set to your.
Cheers.
Laurent Marchal.
> org.eclipse.ui.ide?
Previous Topic:Wwitch between Groups of Key Bindings Dynamically
Next Topic:Where to put log4j.properties
Current Time: Fri Nov 14 19:49:46 EST 2025
Powered by FUDForum. Page generated in 0.15235 seconds
