Home » Eclipse Projects » Eclipse Platform » [Databinding] Need cron-like use-case help
[Databinding] Need cron-like use-case help [message #333025] Thu, 20 November 2008 04:56 Go to next message
Hello Eclipse developers!
Currently I am introducing Databinding in my project (to be concrete EMF
Databinding) and I have the following use-case, where it don't know if I
am on the right way...
Let me explain:
Use-case:
I have an editor where I can edit a Cron expression.
Model:
My model that stores a Cron expression has for every cron part (seconds,
minutes, hours, ... ) a String attribute.
UI:
For instance the month part of the cron expression has 12 SWT
Push-Buttons, labeled from "1" to "12". So when the user clicks the button
"2" then the databinder should add the value "2" to the month attribute of
my model instance. The same applies to every button. When the user
deselects a button than the value should be removed from the string.
To achieve this use case with databinding I would have to bind each of the
12 buttons to my "month" attribute string of my model. Then I would have
to somehow convert the values from a boolean (if the button has been
selected or not) to a string... with a IConverter... can you give me any
hints, if I am on the right way?!
Thank you very much,
Matthias
Re: [Databinding] Need cron-like use-case help [message #333059 is a reply to message #333025] Sun, 23 November 2008 20:06 Go to previous message
You need a helper object that maps booleans to seconds/minutes/hours. For
an example, have a look at
org.eclipse.jface.examples.databinding.model.PriceModelObjec t in
org.eclipse.jface.tests.databinding, it does the same kind of thing for
"price" and "dollars"/"cents".
Boris
"Matthias Treitler" <matthias.treitler@gmail.com> wrote in message
news:8e0b988292988a193d8e13e47af8572c$1@www.eclipse.org...
> Let me explain:
> Use-case:
> Model:
> UI:
> Matthias
Previous Topic:Can a view be fast and sticky at the same time?
Next Topic:Databinding Access Restriction
Current Time: Tue Jul 22 15:45:57 EDT 2025
Powered by FUDForum. Page generated in 0.03014 seconds
