Home » Eclipse Projects » Eclipse Platform » How to decorate an image?
How to decorate an image? [message #333006] Wed, 19 November 2008 07:41 Go to next message
I'm using a TreeViewer together with ColumnLabelProviders. I've found out
that there is no DecoratingLabelProvider for columns and therefore I've to
implement decorating myself.
My question is if I have to write the decorating code myself, or is there
a smart helper somewhere?
Id I call:
decorator.decorateImage(image, element);
and get into my decorator it looks like this:
public Image decorateImage(Image image, Object element) {
// TODO Auto-generated method stub
return null;
At this part I would like to get the job done by someone else :)
Re: How to decorate an image? [message #333011 is a reply to message #333006] Wed, 19 November 2008 09:10 Go to previous messageGo to next message
> out that there is no DecoratingLabelProvider for columns and therefore
> I've to implement decorating myself.
> there a smart helper somewhere?
> Id I call:
> @Override
> return null;
Maybe to this one?
https://bugs.eclipse.org/bugs/attachment.cgi?id=88319
HTH && Greetings from Bremen,
Daniel Krügler
Re: How to decorate an image? [message #333012 is a reply to message #333011] Wed, 19 November 2008 09:22 Go to previous messageGo to next message
>> Id I call:
>> @Override
>> return null;
> Maybe to this one?
Btw.: As of Eclipse 3.4 you have DecoratingStyledCellLabelProvider
available.
- Daniel
Re: How to decorate an image? [message #333014 is a reply to message #333012] Wed, 19 November 2008 10:25 Go to previous messageGo to next message
Thank you Daniel!
DecoratingStyledCellLabelProvider needs a ILabelDecorator in its
contructor. Does'nt I end up at exactly the same possition where I was
when using it?
Or is there a smart way to get the labeldecorator and decoration context?
Its somehow hard to finde examples even using google.
Jan
Re: How to decorate an image? [message #333015 is a reply to message #333014] Wed, 19 November 2008 10:29 Go to previous message
Just found:
http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. platform.doc.isv/whatsNew/platform_isv_whatsnew.html
Previous Topic:strange warning on an ant build.xml file
Next Topic:Preventing the renaming of a resource (not renamed via refactoring actions)
Current Time: Fri Nov 07 20:16:27 EST 2025
Powered by FUDForum. Page generated in 0.04394 seconds
