| How can I upload the file named "Administrator.java" to CVS server [message #33793] |
Sun, 13 March 2005 23:10   |
Eclipse User  |
Originally posted by: wx_new.yahoo.co.jp
How can I upload the file named "Administrator.java" to CVS server.
if I change the name to another else, It is no any problem, but now I
should use that name.
Perhaps CVS server is Using the word of "administrator" I think, but is
there no way to upload the file named "Administrator.java" to CVS server?
help me please ,thanks,
/ wx
| Re: How can I upload the file named "Administrator.java" to CVS server [message #35257 is a reply to message #34547] |
Tue, 15 March 2005 18:56   |
Eclipse User  |
Originally posted by: SamMesh.gmail.com
Probably, here is your *case* :)
http://www.massconfusion.com/tim/notes/cvs_1.11.txt
Look for "!= NULL" (at the end).
HTH,
Sam Mesh
wangxuan wrote:
> when "cvs commit" command execute, error happened at server.
> error message :
>  BPW5.0: assertion "key != NULL" failed: file
> "/usr/src/cvs/cvs-1.11.5/src/hash.c", line 312
>  BPW5.0: cvs [server aborted]: received abort signal
> by the way: BPW5.0 is my project
> thanks for your help.
> Jeff Myers wrote:
>> I doubt there's a limitation in CVS preventing you from checking in
>> this file.  What is the exact error message you receive when you
>> attempt to check in Administrator.java to cvs?
>>   - Jeff
>> wangxuan wrote:
>>> Hi,
>>> is there no way to upload the file named "Administrator.java" to CVS
>>> server?
FUDForum. Page generated in 0.11294 seconds
