Home » Eclipse Projects » Eclipse Platform » CNF: New project wizard > right-click menu > always enabled
CNF: New project wizard > right-click menu > always enabled [message #332988] Tue, 18 November 2008 05:38 Go to next message
I have a wizard for new project. I want to make this wizard always available
in the right-click > New menu. From what I read around the web, it seems
it's a must to use the commonWizard element under the navigatorContent
extensionPoint. I need to know what do I provide in the <enablement> clause
to make it always enabled. I tried using count with value=* but it throws:
org.eclipse.core.runtime.CoreException: The default variable is not of type
java.util.Collection. Failed expression:
org.eclipse.core.internal.expressions.CountExpression@fc8b68b6
Any help would be appreciated.
Rahul
Re: New project wizard > right-click menu > always enabled [message #333057 is a reply to message #332988] Sat, 22 November 2008 05:52 Go to previous messageGo to next message
Ok, I managed to get through this one. Keeping the enablement empty does the
trick (<enablement></enablement>) it seems.
Rahul
"Rahul Kamdar" <rtkamdar@kamdars-india.com> wrote in message
news:gfu5v8$7hl$1@build.eclipse.org...
> available in the right-click > New menu. From what I read around the web,
> it seems it's a must to use the commonWizard element under the
> navigatorContent extensionPoint. I need to know what do I provide in the
> <enablement> clause to make it always enabled. I tried using count with
> type java.util.Collection. Failed expression:
> Rahul
Re: New project wizard > right-click menu > always enabled [message #333243 is a reply to message #333057] Mon, 01 December 2008 18:57 Go to previous messageGo to next message
WOuld you mind filing a bug about this to platform UI, I have run into
this problem myself (looking for just having "true" as a value), and we
should make it abundantly clear in the documentation how to easily do this.
Francis
> Rahul
>> Thanks,
>> Rahul
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: New project wizard > right-click menu > always enabled [message #335515 is a reply to message #333243] Sat, 11 April 2009 11:07 Go to previous message
Originally posted by: me.rahulkamdar.com
Sorry for the delay! Bug filed:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=271936
"Francis Upton (News)" <francisu@ieee.org> wrote in message
news:493479F9.9050001@ieee.org...
> this.
> Francis
>> the trick (<enablement></enablement>) it seems.
>> Rahul
>>> Hi,
>>> web, it seems it's a must to use the commonWizard element under the
>>> Thanks,
>>> Rahul
Previous Topic:Problems with WorkspaceModifyOperation and IProgressService.run(...)
Next Topic:eclipse.org/examples vs. platform examples
Current Time: Fri Nov 21 09:01:02 EST 2025
Powered by FUDForum. Page generated in 0.04761 seconds
