Home » Eclipse Projects » Eclipse Platform » Parameters provided to IElementUpdater.updateElement()
Parameters provided to IElementUpdater.updateElement() [message #332986] Tue, 18 November 2008 04:14 Go to next message
Hi there!
I have a command handler implementing IElementUpdater. Through debugging and trial & error i found
out that the parameters Map contains a IWorkbenchPartSite that can be accessed like this:
public void updateElement(final UIElement element, final Map parameters) {
final IWorkbenchPartSite partSite = (IWorkbenchPartSite) parameters
.get("org.eclipse.ui.part.IWorkbenchPartSite");
I guess it is the IWorkbenchPartSite where the given UIElement is "shown" in the GUI. That is, the
code works as expected.
Can somebody please confirm this?
Is there some more documentation about IElementUpdater?
Thnx,
Marcel
Re: Parameters provided to IElementUpdater.updateElement() [message #332989 is a reply to message #332986] Tue, 18 November 2008 06:03 Go to previous messageGo to next message
Marcel Hoetter wrote:
> Hi there!
> and trial & error i found out that the parameters Map contains a
> "shown" in the GUI. That is, the code works as expected.
You should have a look at the documentation of UIElement, which
is one of the function parameters. The documentation of it's method
getServiceLocator() says:
"[..] The locator may be used to obtain services that are scoped in
the same way as the {@link UIElement}. Such services include but are
not limited to {@link IWorkbench}, {@link IWorkbenchWindow}, and
{@link IWorkbenchPartSite}.[..]"
The documentation of it's Map parameter says only that it contains all
parameters registered with the callback, so this seems of little help here.
I suggest using the official route: Retrieve the IWorkbenchPartSite
from the UIElement#getServiceLocator() and you are done.
HTH & Greetings from Bremen,
Daniel Krügler
Re: Parameters provided to IElementUpdater.updateElement() [message #332994 is a reply to message #332989] Tue, 18 November 2008 10:42 Go to previous messageGo to next message
Well, i did have a look at the documentation of IElementUpdater, but...
....exactly. How and where does one "register parameters with the callback"?
Regarding the UIElement and it's getServiceLocator() method:
Thanks for this input! However, I tried this and obviously the IServiceLocator returned by this
method does not have an IWorkbenchPartSite in it's scope. In other words..
(IWorkbenchPartSite)element.getServiceLocator()
.getService(IWorkbenchPartSite.class);
....only returns null. (Or am i doing something wrong here?)
Re: Parameters provided to IElementUpdater.updateElement() [message #333001 is a reply to message #332994] Wed, 19 November 2008 04:37 Go to previous messageGo to next message
> here.
AFAIK you can add parameters via the <parameter> section of the
org.eclipse.ui.menus ext.pt (child of <command>). It should also
be possible to add parameters programmatically (see below).
> IServiceLocator returned by this method does not have an
Interesting, I hadn't expected that. I found another example
http://kickjava.com/src/org/eclipse/ui/internal/handlers/Tog gleCoolbarHandler.java.htm
which seems to imply that you need to add the IWorkbenchPartSite
in your AbstractHandler#execute method (untested):
public Object JavaDoc execute(ExecutionEvent event) throws
ExecutionException {
final IWorkbenchSite activeSite = HandlerUtil
.getActiveSiteChecked(event);
Map filter = new HashMap();
filter.put(IServiceScopes.PARTSITE_SCOPE, activeSite);
commandService.refreshElements(event.getCommand().getId(), filter);
HTH,
Daniel
Re: Parameters provided to IElementUpdater.updateElement() [message #333067 is a reply to message #332994] Mon, 24 November 2008 08:20 Go to previous messageGo to next message
Gah! I almost dropped my coffee (that's twice in 2 weeks :-)
That appears to be a regression from 3.3. Please open a bug at
https://bugs.eclipse.org/bugs/
Paul Webster
Re: Parameters provided to IElementUpdater.updateElement() [message #333075 is a reply to message #333001] Mon, 24 November 2008 11:16 Go to previous messageGo to next message
Ah! I new that those parameters could be retrieved from the
ExecutionEvent object passed by the framework to the IHandler.execute() method.
I was not aware that they are also provided to the IElementUpdater.updateElement()
method. Makes sense, i guess! Thanks! :)
Nice website! Bookmarked it...
I already make use of the filter to scope the refreshElements() method to the one view that
actually needs to be updated.
>> parameters) {
No wonder: this is a bug according to Pauls post. (see below)
Re: Parameters provided to IElementUpdater.updateElement() [message #333076 is a reply to message #333067] Mon, 24 November 2008 11:20 Go to previous message
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=256293
Previous Topic:Cannot find the button to reset or forget the dialog settings
Next Topic:Lateral menu using fast view / Presentation framework
Current Time: Tue Nov 18 17:50:18 EST 2025
Powered by FUDForum. Page generated in 0.04617 seconds
