Home » Eclipse Projects » Eclipse Platform » Contributing org.eclipse.ui.menus to actionSets
Contributing org.eclipse.ui.menus to actionSets [message #332968] Mon, 17 November 2008 10:09 Go to next message
I try to contribute a command using the org.eclipse.ui.menus extension
point to an existing menu which was defined inside an actionSet. Is this
at all possible?
If yes, what is the locationUri I can use to specify the menu from the
actionSet?
Iwan
Re: Contributing org.eclipse.ui.menus to actionSets [message #333065 is a reply to message #332968] Mon, 24 November 2008 07:52 Go to previous message
No, it's not possible. actionSets can't even see other actionSets, so
while actionSets *can* see org.eclipse.ui.menus, contributions from
org.eclipse.ui.menus cannot see actionSets
PW
Paul Webster
Previous Topic:Databinding Access Restriction
Next Topic:<adapt>-Problem
Current Time: Tue Nov 04 19:35:17 EST 2025
Powered by FUDForum. Page generated in 0.03453 seconds
