Home » Eclipse Projects » Eclipse Platform » Eclipse view plugin: swing problem
Eclipse view plugin: swing problem [message #332967] |
Mon, 17 November 2008 10:05  |
Thanks in advance for any help that could be provided.
I am new to the Eclipse plugin world. I have a very short amount of time
to complete my project and do not have time to learn the SWT library. I am
very familiar with the Swing library and i have found a way to wrap Swing
into the view by doing the following.
public void createPartControl(Composite parent) {
try{
UIManager.setLookAndFeel("com.sun.java.swing.plaf.windows.WindowsLookAndFeel ");
}catch (Exception e){
//TODO: manage exception
Composite swtAwtComponent = new Composite(parent, SWT.EMBEDDED);
java.awt.Frame frame = SWT_AWT.new_Frame( swtAwtComponent );
Ftie_ui ui = new Ftie_ui();
frame.add(ui);
The Ftie_ui class extends JPanel. Normally, with access to a JPanel, I
figured it would be easy to develop my project with Swing. I added 2
JLabels, 1 JTextField, 1 JPasswordField and 1 JButton. When i ran Eclipse
with my plugin, Everything got loaded in my JPanel, but i could not access
the JTextField and the JPasswordField. I have tryed setEnabled(true) and
setEditable(true) on the fields, but with no success, I could not manage
to put a cursor is the fields. The Ftie_ui class looks like the following
(I know, theres no layout yet).
I am running, windows vista 32bit, java 1.6, Eclipse 3.4.0
I will supply a complete code snippet in case it would help.
For any help someone could bring, I would greatly appreciate it.
Thank you
Ben
package ftie.views;
import javax.swing.*;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.ui.part.*;
import org.eclipse.swt.awt.SWT_AWT;
import org.eclipse.ui.*;
import org.eclipse.swt.SWT;
public class FtieView extends ViewPart {
Composite swtAwtComponent;
java.awt.Frame frame;
Ftie_ui ui;
public FtieView() {
try{
ui = new Ftie_ui();
frame.add(ui);
public void setFocus() {
package ftie.views;
public class Ftie_ui extends JPanel{
JLabel labelUser;
JLabel labelPass;
JTextField txtUser;
JPasswordField txtPass;
JButton btnLogin;
public Ftie_ui()
//TODO: add layout
labelUser = new JLabel();
labelUser.setText("Username:");
labelPass = new JLabel();
labelPass.setText("Password:");
txtUser = new JTextField(20);
txtUser.setEditable(true);
txtUser.setEnabled(true);
txtPass = new JPasswordField(20);
btnLogin = new JButton("Login");
add(labelUser);
add(labelPass);
add(txtUser);
add(txtPass);
add(btnLogin);
Re: Eclipse view plugin: swing problem [message #332970 is a reply to message #332967] |
Mon, 17 November 2008 10:15   |
Hi Ben,
I don't know how to solve but I've included the albireo newsgroup which
deals with Swing/SWT.
The problem looks like the Swing event loop is not working appropiately
hence no events are delivered to the Swing components.
Tom
Ben schrieb:
> am very familiar with the Swing library and i have found a way to wrap
> Swing into the view by doing the following.
> try{
> SWT.EMBEDDED);
> frame.add(ui);
> Eclipse with my plugin, Everything got loaded in my JPanel, but i could
> not access the JTextField and the JPasswordField. I have tryed
> setEnabled(true) and setEditable(true) on the fields, but with no
> success, I could not manage to put a cursor is the fields. The Ftie_ui
> class looks like the following (I know, theres no layout yet).
> Thank you
> Ben
> package ftie.views;
> Ftie_ui ui;
> public FtieView() {
> try{
> ui = new Ftie_ui();
> frame.add(ui);
> package ftie.views;
> JLabel labelUser;
> JLabel labelPass;
> JTextField txtUser;
> JButton btnLogin;
> public Ftie_ui()
> //TODO: add layout
> add(labelUser);
> add(labelPass);
> add(txtUser);
> add(txtPass);
> add(btnLogin);
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Eclipse view plugin: swing problem [message #332987 is a reply to message #332970] |
Tue, 18 November 2008 05:33  |
Hi Ben,
I make use of SWT_AWT bridge successfully to bring panels from Swing
application into SWT/Eclipse. First thing, if it's possible use Albireo
since SWT_AWT has some bugs and issues and the workarounds could be tricky
depending on your requirements.
Try the following to see if it works:
Hold the composite object > parent in a global variable at your FtieView
class level. Then override the "setFocus" method of "ViewPart" and in this
createPartControl with the global parent object. This is not the best way
but if it works then we could try the workaround.
Rahul
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:gfs1pu$chn$1@build.eclipse.org...
> Hi Ben,
> Tom
> Ben schrieb:
>> try{
>> SWT.EMBEDDED);
>> frame.add(ui);
>> Thank you
>> Ben
>> package ftie.views;
>> Ftie_ui ui;
>> public FtieView() {
>> try{
>> ui = new Ftie_ui();
>> frame.add(ui);
>> package ftie.views;
>> JLabel labelUser;
>> JLabel labelPass;
>> JTextField txtUser;
>> JButton btnLogin;
>> public Ftie_ui()
>> //TODO: add layout
>> add(labelUser);
>> add(labelPass);
>> add(txtUser);
>> add(txtPass);
>> add(btnLogin);
Current Time: Sun Aug 31 08:29:43 EDT 2025
Powered by FUDForum. Page generated in 0.06471 seconds
