Home » Eclipse Projects » Eclipse Platform » Eclipse view plugin: swing problem
Eclipse view plugin: swing problem [message #332967] Mon, 17 November 2008 10:05 Go to next message
Thanks in advance for any help that could be provided.
I am new to the Eclipse plugin world. I have a very short amount of time
to complete my project and do not have time to learn the SWT library. I am
very familiar with the Swing library and i have found a way to wrap Swing
into the view by doing the following.
public void createPartControl(Composite parent) {
try{
UIManager.setLookAndFeel("com.sun.java.swing.plaf.windows.WindowsLookAndFeel ");
}catch (Exception e){
//TODO: manage exception
Composite swtAwtComponent = new Composite(parent, SWT.EMBEDDED);
java.awt.Frame frame = SWT_AWT.new_Frame( swtAwtComponent );
Ftie_ui ui = new Ftie_ui();
frame.add(ui);
The Ftie_ui class extends JPanel. Normally, with access to a JPanel, I
figured it would be easy to develop my project with Swing. I added 2
JLabels, 1 JTextField, 1 JPasswordField and 1 JButton. When i ran Eclipse
with my plugin, Everything got loaded in my JPanel, but i could not access
the JTextField and the JPasswordField. I have tryed setEnabled(true) and
setEditable(true) on the fields, but with no success, I could not manage
to put a cursor is the fields. The Ftie_ui class looks like the following
(I know, theres no layout yet).
I am running, windows vista 32bit, java 1.6, Eclipse 3.4.0
I will supply a complete code snippet in case it would help.
For any help someone could bring, I would greatly appreciate it.
Thank you
Ben
package ftie.views;
import javax.swing.*;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.ui.part.*;
import org.eclipse.swt.awt.SWT_AWT;
import org.eclipse.ui.*;
import org.eclipse.swt.SWT;
public class FtieView extends ViewPart {
Composite swtAwtComponent;
java.awt.Frame frame;
Ftie_ui ui;
public FtieView() {
try{
ui = new Ftie_ui();
frame.add(ui);
public void setFocus() {
package ftie.views;
public class Ftie_ui extends JPanel{
JLabel labelUser;
JLabel labelPass;
JTextField txtUser;
JPasswordField txtPass;
JButton btnLogin;
public Ftie_ui()
//TODO: add layout
labelUser = new JLabel();
labelUser.setText("Username:");
labelPass = new JLabel();
labelPass.setText("Password:");
txtUser = new JTextField(20);
txtUser.setEditable(true);
txtUser.setEnabled(true);
txtPass = new JPasswordField(20);
btnLogin = new JButton("Login");
add(labelUser);
add(labelPass);
add(txtUser);
add(txtPass);
add(btnLogin);
Re: Eclipse view plugin: swing problem [message #332970 is a reply to message #332967] Mon, 17 November 2008 10:15 Go to previous messageGo to next message
Hi Ben,
I don't know how to solve but I've included the albireo newsgroup which
deals with Swing/SWT.
The problem looks like the Swing event loop is not working appropiately
hence no events are delivered to the Swing components.
Tom
Ben schrieb:
> am very familiar with the Swing library and i have found a way to wrap
> Swing into the view by doing the following.
> try{
> SWT.EMBEDDED);
> frame.add(ui);
> Eclipse with my plugin, Everything got loaded in my JPanel, but i could
> not access the JTextField and the JPasswordField. I have tryed
> setEnabled(true) and setEditable(true) on the fields, but with no
> success, I could not manage to put a cursor is the fields. The Ftie_ui
> class looks like the following (I know, theres no layout yet).
> Thank you
> Ben
> package ftie.views;
> Ftie_ui ui;
> public FtieView() {
> try{
> ui = new Ftie_ui();
> frame.add(ui);
> package ftie.views;
> JLabel labelUser;
> JLabel labelPass;
> JTextField txtUser;
> JButton btnLogin;
> public Ftie_ui()
> //TODO: add layout
> add(labelUser);
> add(labelPass);
> add(txtUser);
> add(txtPass);
> add(btnLogin);
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Eclipse view plugin: swing problem [message #332982 is a reply to message #332967] Mon, 17 November 2008 16:35 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
This is probably related to a focus problem with the swt_awt bridge.
It is better to use the Albireo project
http://wiki.eclipse.org/Albireo_Project
The open bugs are summarized on the website
http://wiki.eclipse.org/Albireo_SWT_AWT_bugs
Additionally read this article
http://www.eclipse.org/articles/article.php?file=Article-Swi ng-SWT-Integration/index.html
about the problems which can occur when using the swt_awt
bridge.
I hope this helps
Re: Eclipse view plugin: swing problem [message #332987 is a reply to message #332970] Tue, 18 November 2008 05:33 Go to previous message
Hi Ben,
I make use of SWT_AWT bridge successfully to bring panels from Swing
application into SWT/Eclipse. First thing, if it's possible use Albireo
since SWT_AWT has some bugs and issues and the workarounds could be tricky
depending on your requirements.
Try the following to see if it works:
Hold the composite object > parent in a global variable at your FtieView
class level. Then override the "setFocus" method of "ViewPart" and in this
createPartControl with the global parent object. This is not the best way
but if it works then we could try the workaround.
Rahul
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:gfs1pu$chn$1@build.eclipse.org...
> Hi Ben,
> Tom
> Ben schrieb:
>> try{
>> SWT.EMBEDDED);
>> frame.add(ui);
>> Thank you
>> Ben
>> package ftie.views;
>> Ftie_ui ui;
>> public FtieView() {
>> try{
>> ui = new Ftie_ui();
>> frame.add(ui);
>> package ftie.views;
>> JLabel labelUser;
>> JLabel labelPass;
>> JTextField txtUser;
>> JButton btnLogin;
>> public Ftie_ui()
>> //TODO: add layout
>> add(labelUser);
>> add(labelPass);
>> add(txtUser);
>> add(txtPass);
>> add(btnLogin);
Previous Topic:CompareEditorInput setDirty difference between eclipse 3.2 and 3.3
Next Topic:Error updating clean Ganymede SR1 (only Linux)
Current Time: Sun Aug 31 15:08:09 EDT 2025
Powered by FUDForum. Page generated in 0.03815 seconds
