Home » Eclipse Projects » Eclipse Platform » [Menu Contributions] toolbar does not show up in view
[Menu Contributions] toolbar does not show up in view [message #332946] Sat, 15 November 2008 19:21 Go to next message
Hello.
I have some problems with the more or less new menu contributions framework.
I want to add something to my own views toolbar, but it does not show
up. When I add it to the main toolbar
(toolbar:org.eclipse.ui.main.toolbar) it works.
Here an little extract from my plugin.xml:
<menuContribution
locationURI="toolbar:org.pubcurator.val.views.validationPipeline ">
<toolbar
id="org.pubcurator.val.toolbars.pipelineNavigation">
<command
commandId="org.pubcurator.val.commands.previous"
icon="icons/up_arrow.gif"
mnemonic="P"
style="push">
</command>
<command
commandId="org.pubcurator.val.commands.next"
icon="icons/down_arrow.gif"
mnemonic="N"
style="push">
</command>
</toolbar>
</menuContribution>
I also use that code in the view:
getViewSite().getActionBars().getToolBarManager().add(new
Separator(IWorkbenchActionConstants.MB_ADDITIONS));
Do I have to do something else?
Kai
Re: [Menu Contributions] toolbar does not show up in view [message #332947 is a reply to message #332946] Sat, 15 November 2008 19:52 Go to previous messageGo to next message
Ok, the problem seems to be somewhere else.
When I swith to another perspective resp. maximize another view and then
switch back to the former view resp. restore my view by minimizing the
other maximized view, then my view toolbar shows up.
Any suggestions how to make my toolbar visible right after program start?
Kai
Kai Schlamp schrieb:
> Hello.
> framework.
> <menuContribution
> <toolbar
> <command
> mnemonic="P"
> style="push">
> </command>
> <command
> mnemonic="N"
> style="push">
> </command>
> </toolbar>
> </menuContribution>
> Best regards,
> Kai
Re: [Menu Contributions] toolbar does not show up in view [message #332951 is a reply to message #332947] Sun, 16 November 2008 07:00 Go to previous message
Problem solved.
It had to do something with a visibleWhen clause, that I left out in my
little extract below :-(
Kai
> Best regards,
> Kai
>> Hello.
>> framework.
>> <menuContribution
>> <toolbar
>> <command
>> mnemonic="P"
>> style="push">
>> </command>
>> <command
>> mnemonic="N"
>> style="push">
>> </command>
>> </toolbar>
>> </menuContribution>
>> Best regards,
>> Kai
Previous Topic:batik feature missing?
Next Topic:Problems creating update site
Current Time: Sat Nov 08 08:57:07 EST 2025
Powered by FUDForum. Page generated in 0.03300 seconds
