Home » Eclipse Projects » Eclipse Platform » JavaSearchResultPage
JavaSearchResultPage [message #332943] Sat, 15 November 2008 04:37 Go to next message
Is it possible to reuse the existing eclipse java search input dialog, by
defining an extension point such as
1. <extension point="org.eclipse.search.searchPages">
2. <page id="org.eclipse.jdt.ui.JavaSearchPage">
3. icon="icons/full/obj16/jsearch_obj.png"
4. label="%JavaSearchPage.label"
5. sizeHint="460,160"
6. extensions="java:90, jav:90"
7. showScopeSection="true"
8. canSearchEnclosingProjects="true"
9. class="org.eclipse.jdt.internal.ui.search.JavaSearchPage">
10. </page>
11. </extension>
and have it send the search results to a customised JavaSearchResultPage?
<extension>
id="JavaSearchResultPage"
point="org.eclipse.search.searchResultViewPages">
<viewpage>
id="org.eclipse.jdt.ui.JavaSearchResultPage"
searchResultClass="org.eclipse.jdt.internal.ui.sea rch.JavaSearchResult"
class="my.custom.MyCustomJavaSearchResultPage">
</viewpage>
</extension>
I don't want to duplicate the search input dialog, but would like to be
able to have better control over the export options on the matched java
source tree/table in the search results panel. The examples i've found
have all had a custom search input dialog which i don't need. Any idea's,
pointers or workarounds would be appreciated.
Re: JavaSearchResultPage [message #332959 is a reply to message #332943] Mon, 17 November 2008 04:27 Go to previous message
> by defining an extension point such as
No, this is not possible.
Dani
> 10. </page>
> 11. </extension>
> <extension>
> <viewpage>
> </viewpage>
> </extension>
> be able to have better control over the export options on the matched
> java source tree/table in the search results panel. The examples i've
> found have all had a custom search input dialog which i don't need.
> Any idea's, pointers or workarounds would be appreciated.
Previous Topic:Specify whether an IEditorPart is closeable or not
Next Topic:How to show Capabilities
Current Time: Fri Nov 07 18:41:37 EST 2025
Powered by FUDForum. Page generated in 0.03626 seconds
