Home » Eclipse Projects » Eclipse Platform » Adding ContributionItem directly to Coolbar causes all Separators to be invisible.
Adding ContributionItem directly to Coolbar causes all Separators to be invisible. [message #332940] Fri, 14 November 2008 14:22 Go to next message
After adding a toolbarManager directly to the Coolbar causes all the
Separators in the all toolbars to go invisible. they are still there,
there's still an extra space but they are not visible.
simply doing the following code causes the issue... what am i doing wrong?
CoolBarManager coolBarManager = ( (WorkbenchWindow) window
).getCoolBarManager();
newToolbarManager = new ToolBarManager2();
ToolBarContributionItem tbci = new
ToolBarContributionItem2(newToolbarManager, element.getId());
coolBarManager.insertAfter( element.getId(), tbci );
coolBarManager.markDirty();
((WorkbenchWindow)window).updateActionBars();
kjm
Re: Adding ContributionItem directly to Coolbar causes all Separators to be invisible. [message #333052 is a reply to message #332940] Fri, 21 November 2008 15:00 Go to previous message
Wow, this is so the opposite of supported :-)
If your tbci id is element.getId(), then how can you
insertAfter(element.getId, ...) ? What if you pick an ID in the coolbar
that already exists?
Later,
PW
Paul Webster
Previous Topic:Using eclipse on Windows2003 with multiple users
Next Topic:Active Contexts and Pages in the MultiPageEditorPart
Current Time: Thu Jul 17 23:50:36 EDT 2025
Powered by FUDForum. Page generated in 0.05640 seconds
