Home » Eclipse Projects » Eclipse Platform » Form not showing Vertical Scrool
Form not showing Vertical Scrool [message #332874] Wed, 12 November 2008 14:36 Go to next message
Originally posted by: dave.dave.net
I've implemnted an Form in an editor using the EditorPart class.
in the
public void createPartControl(Composite parent) function, I have
toolkit = new FormToolkit(parent.getDisplay());
form = toolkit.createScrolledForm(parent);
form.setText("ModelML Overview");
form.getBody().setLayout(new GridLayout(2,true));
and multiple
Section section =
toolkit.createSection(form.getBody(),Section.DESCRIPTION|Sec tion.TITLE_BAR|
Section.TWISTIE|Section.EXPANDED);
This is all pretty straight forward and the UI renders correctly except
the vertical scroll. If i collapse one of the section, the vertical
scroll will then correctly show up in the editor.
Any idea where I've gone wrong ?
Thanks, Dave
Re: Form not showing Vertical Scrool [message #332905 is a reply to message #332874] Thu, 13 November 2008 09:55 Go to previous message
Originally posted by: blah.blah.net
I've realized that one problem is that I didn't do parent.pack(), to
calculate the size but the size given is the preferred size not the
actual layout size. This is effecting some of the table column
calculation. Does anyone know how to get the composite to calculate the
actual size after the layout has been calculate ?
Thanks, Dave
David wrote:
> Hi
> in the
> and multiple
> Section section =
> Thanks, Dave
> Hi
> in the
> and multiple
> Section section =
> Thanks, Dave
Previous Topic:Context Menu from a Column Header in a TreeViewer??
Next Topic:F10 key mapping / Ubuntu (Gnome)
Current Time: Tue Nov 18 07:15:45 EST 2025
Powered by FUDForum. Page generated in 0.02965 seconds
