Home » Eclipse Projects » Eclipse Platform » How to find dependencies of plug-in?
How to find dependencies of plug-in? [message #332818] Mon, 10 November 2008 12:54 Go to next message
Could someone tell me how to programmatically find the dependencies
(required plug-ins) of a plug-in (say org.eclipse.ui for instance)?
I tried using class org.osgi.framework.Bundle, but still have had no luck.
Thanks in advance!
Sudarsha Wijenayake
Re: How to find dependencies of plug-in? [message #332826 is a reply to message #332818] Mon, 10 November 2008 16:15 Go to previous messageGo to next message
I looked around for you seems like you want to take a look at
Bundle.getHeaders() as I think there is a header that specifies the list
of dependent plugins declared in the plugin's MANIFEST.
http://www.ibm.com/developerworks/library/os-eclipse-bundlem gmt/index.html
has a table of headers and the Require-Bundle is the header that I think
should contain that information. Hope that helps. - Duncan
Re: How to find dependencies of plug-in? [message #332869 is a reply to message #332818] Tue, 11 November 2008 13:28 Go to previous message
You need to work with BundleDescription objects. And then use
StateHelper which has a number of interesting methods.
To get BundleDescription objects, you will need to use the PlatformAdmin
service. The easiest way to get the service is
Platform#getPlatformAdmin().
Then you need the State (PlatformAdmin#getState()), the state has
State#getBundle(long) iwhere you can pass in your Bundle#getBundleId().
-Andrew
Sudarsha Wijenayake wrote:
> Hello,
> Thanks in advance!
> Sudarsha Wijenayake
Previous Topic:Delete/Purge old plugins
Next Topic:Question about IAutoEditStrategy
Current Time: Sun Aug 31 12:43:22 EDT 2025
Powered by FUDForum. Page generated in 0.06393 seconds
